350 Idle Speed? - Chevelle Tech
post #1 of 7 (permalink) Old Oct 1st, 11, 5:40 AM Thread Starter
Karl
350 Idle Speed?
350/350, RV cam, headers, 4 barrel Quadrajet carb. Anyone have any idea what the approx idle speed would be? Carb was rebuilt and idle is high.
1971 Chevelle in the works. 450hp 383. Hi Perf TH350 w/ 2400 stall. 12 Bolt 3.55 Posi.
karl is offline
post #2 of 7 (permalink) Old Oct 1st, 11, 5:45 AM
Send a message via AIM to bri2203
Re: 350 Idle Speed?
550-600 in gear
UNDER CONSTRUCTION
1970 Malibu Hardtop with Fiber optics and electrotip wipers.
bri2203 is offline
post #3 of 7 (permalink) Old Oct 1st, 11, 5:50 AM Thread Starter
Karl
Re: 350 Idle Speed?
So what your saying is have someone hold their foot on the brake in gear while i hook up a tach and adjust it?
karl is offline
post #4 of 7 (permalink) Old Oct 1st, 11, 9:52 AM
leo
Re: 350 Idle Speed?
park brake, chock the wheels and someone with their foot on the brake if necessary.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
www.mdchevelleclub.com
LeoP is offline
post #5 of 7 (permalink) Old Oct 1st, 11, 11:06 AM
Matt
Re: 350 Idle Speed?
700-750 in park. Put it in gear and you should have 550-600.
1966 Chevy Caprice 2 door sport coupe
396 325 h.p. 95% original, matching #'s
Th400, 2:73 12 bolt
Original dealer invoice, title from orig. owner, Protecto-plate
Mods:
Dual flowmasters
Edelbrock 1406 600 cfm carb
Pertronix points eliminator
Adjustable vac can and re-curve
Open element aircleaner with 3" K&N
2000 rpm stall
Trans-Go shift kit
matt's66 is offline
post #6 of 7 (permalink) Old Oct 1st, 11, 6:57 PM
Lonnie
Re: 350 Idle Speed?
are you sure the choke isnt set engaging high idle?
462 chevelle is offline
post #7 of 7 (permalink) Old Oct 1st, 11, 7:37 PM Thread Starter
Karl
Re: 350 Idle Speed?
Has remote choke with spring. Very simple setup. Like they should be. Will try and adjust idle speed 1st. I dont like the in gear idea.Thanks
karl is offline
This Thread is more than 2091 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
