396 oil filter leak - Chevelle Tech
post #1 of 44 (permalink) Old Feb 9th, 11, 8:55 AM Thread Starter
Giorgio.RS
396 oil filter leak
guys,
have a serious leak problem in my engine. We just rebuild it, everything is normal when put oil and start to load the tappets.. but when the engine start for the first time lots of oli come out from oil filter. and the leak happens just when we star the engine.
I change the filter for other brand, same thing, leak...
I change the oil filter adapter and still leak...
I change the rubber from oil filter for a taller one, for more grip.. still leak
I drain all oil, thake the oil pan out to check if the oil pump valve itīs ok, and itīs fine!
Iīm using a new Sealed Power Z2244153 - Sealed Power High Volume Oil Pumps
I donīt no what is going on, should i change the oil pump for a standar volume?
note the pic 6070 the oil filter is crooked a little to left, that happens in the last try.. the pressure was about 20 PSI at gauge. the engine start and at the same tame we have to turn it of because of oil leak.
thx
Giorgio
ID:	38705   Click image for larger version
ID:	38706   Click image for larger version
ID:	38707   Click image for larger version
Giorgio.RS is offline
post #2 of 44 (permalink) Old Feb 9th, 11, 9:50 AM
Re: 396 oil filter leak
You sure it's not running down from that compression fitting above?
post #3 of 44 (permalink) Old Feb 9th, 11, 10:13 AM
It looks crooked to me I would remove the adaptor from the block to see if there is something stopping it from sitting flat on the block. Make sure the filter is not hitting the bolts on the adaptor.
1969 Nova SS
502 CID
Pro Systems
cstraub big squishy roller
AutoGear M23W
4:56
jmartorana is offline
post #4 of 44 (permalink) Old Feb 9th, 11, 10:46 AM
kevin
I have an old 1966 396 block. there are a couple of different styles of adapters available and neither worked for me. I ended up just sticking with the old canister style filter. makes a mess but you get a new oring seal with every filter and it hold about another quart of oil.
the heckler is offline
post #5 of 44 (permalink) Old Feb 9th, 11, 10:51 AM Thread Starter
Giorgio.RS
I did! chance the adaptor and still leak...
about the bolts, itīs not hitting, itīs realy close, but not hit
post #6 of 44 (permalink) Old Feb 9th, 11, 11:07 AM Thread Starter
Giorgio.RS
I chance adaptor 2 times.. unsuccessfully - big oil madness!!
Iīm trying to get one of those here in Brazil, but itīs really hard to find..
I have one on my 283 but itīs in use..
how can I search this at ebay? or where can I found it for sell with international shipping?
post #7 of 44 (permalink) Old Feb 9th, 11, 11:29 AM
Anhtuan Le
Giorgio, try the System 1 filters, canister style. you can get it from Jegs or Summit, maybe try to ebay that.
http://www.system1filters.com/
good luck
atle is offline
post #8 of 44 (permalink) Old Feb 9th, 11, 1:16 PM Thread Starter
Giorgio.RS
Thank you very much, Iīll try that!
good luck
post #9 of 44 (permalink) Old Feb 9th, 11, 2:29 PM
Kurt
Is your block supposed to use the canister type filter? If so, I think you need one of these adapters. It can be seen in this picture.
Someone correct me if I'm wrong...it's happened before.
Kurt
1969 Chevelle SS396 300 Deluxe Post Sedan Bench Seat 4-speed
Lemans Blue w/Medium Blue Ransom Cloth Interior
CE 402 M22W 4.56:1 12 bolt
12.15@115
Delivered to Van-T in Topeka, Kansas
A foreign car bought is an American job lost!
TC# 5139
ACES#09593
MCACN Show 2010 http://i300.photobucket.com/albums/n...1010106-11.jpg
Street Trim http://i300.photobucket.com/albums/n...e/100_2256.jpg
69 Post Sedan is offline
post #10 of 44 (permalink) Old Feb 9th, 11, 6:27 PM
Matt
Kurt
x2
65 to 67 blocks need a canister to spin on adapter, otherwise there is nothing for the o-ring to seat on. You need something like this if it's one of the earlier blocks: http://www.summitracing.com/parts/TRD-1024/
1966 Chevy Caprice 2 door sport coupe
396 325 h.p. 95% original, matching #'s
Th400, 2:73 12 bolt
Original dealer invoice, title from orig. owner, Protecto-plate
Mods:
Dual flowmasters
Edelbrock 1406 600 cfm carb
Pertronix points eliminator
Adjustable vac can and re-curve
Open element aircleaner with 3" K&N
2000 rpm stall
Trans-Go shift kit
matt's66 is offline
post #11 of 44 (permalink) Old Feb 9th, 11, 8:47 PM
Big Jim
Originally Posted by matt's66 View Post
x2
x3... check the year of your block. i think these guys are 100% right. my 396 has the same adapter, & it's a non bypass, with zero leaks. the newer one will not work.
67 SS396 : 138 car
4 speed 4:10's
black, w/black guts
waited patiently since 1978.
the 496... impressive.
bodywork prison... paroled. pass out the bud lite
Black Beauty
86 Silverado 4x4....gone to another home!
there was a 96 Z/34 &
another silverado around here somewhere
mryanduv is offline
post #12 of 44 (permalink) Old Feb 10th, 11, 8:50 AM Thread Starter
Giorgio.RS
yes, the canister one
well, letīs try this kind of adapter!
thanks Kurt!
Kurt
post #13 of 44 (permalink) Old Feb 10th, 11, 8:55 AM Thread Starter
Giorgio.RS
my block was produce in 1969
396 - 325HP Hi Per Truck
2 main bolts
this adapter itīs for use normal filters like FRAM HP4, right?
thank you very much for all the tips guys!!
Giorgio
post #14 of 44 (permalink) Old Feb 10th, 11, 9:16 AM Thread Starter
Giorgio.RS
can I use this one?
http://www.summitracing.com/parts/MRG-1270/?rtype=10
Giorgio
x2
post #15 of 44 (permalink) Old Feb 10th, 11, 9:29 AM
Kurt
Giorgio, what is the casting number on your block?
Kurt
12.15@115
TC# 5139
ACES#09593
This Thread is more than 2291 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
