what makes a mild cam not a mild?? - Chevelle Tech
post #1 of 26 (permalink) Old Jan 27th, 11, 3:26 PM Thread Starter
Anhtuan Le
so just reading and thinking... alot of guys mention they have a mild cam and such. i was wondering is there a range that makes a cam a mild cam vs. a radical cam?
so my cam is, is it a mild or something else?
  • Advertised Duration (Int/Exh): 267/273
  • Duration @ .050 (Int/Exh): 237/243
  • Gross Valve Lift (Int/Exh): .639/.655
  • LSA/ICL: 110/106
  • Valve Lash (Int/Exh): .018/.018
  • RPM Range: 2500-6600
atle is offline
post #2 of 26 (permalink) Old Jan 27th, 11, 3:42 PM
Vinny Vince
Re: what makes a mild cam not a mild??
Perception
*11 C6, 6.2, 6spd
69-CHVL is offline
post #3 of 26 (permalink) Old Jan 27th, 11, 4:06 PM
  • LSA/ICL: 110/106
IMO,by looking @ your cam specs I'd say your on the mild/wild border line.
Alot has to do with the rest of the engine combo....what is WILD in a 'race only' 396 will be a kitten in a 572.
& as Vince said....personal perception.
TC#3095
dreis454 is offline
post #4 of 26 (permalink) Old Jan 27th, 11, 4:11 PM
Thats a good street cam. To me mild is when it can support power brakes and can still idle below 1000. I bought a 231/239 @.050 .535/.550 hydro roller for my 350, because it has power brakes. I expect this cam to work just fine. Now my Chevelle has a 275/287 @.050, .788/.765 and idles at 1600.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #5 of 26 (permalink) Old Jan 27th, 11, 4:19 PM
For a solid (roller?) cam in a big block, I'd call that moderate on it's way toward radical...depending on how it sounds at idle.
Like Vince said, it's perception... and I'll add "opinion."
To me, a "mild" cam is bigger than stock but still works with a stock torque converter and a "radical" cam has a really wicked idle at 1000 rpms.
Yellomalibu is offline
post #6 of 26 (permalink) Old Jan 27th, 11, 4:35 PM Thread Starter
Anhtuan Le
thanks guys, it sounds pretty aggressive at idle and idles at 900 very nicely. i've heard some very wicked cars with smaller cam specs than mine, so just curious.
atle is offline
post #7 of 26 (permalink) Old Jan 27th, 11, 4:58 PM
Once upon a time, cams came as stock, street, 3/4 race,and full race, meaning:
---no improvement over stock,
---better but not killer,
---hot street stick,
---and overkill.
HTH
Two Lane is offline
post #8 of 26 (permalink) Old Jan 27th, 11, 6:58 PM
---and overkill.
HTH
Nice.
I'm guessing the "RV cam" is in the same category as the "street" cams, right?
post #9 of 26 (permalink) Old Jan 27th, 11, 11:26 PM
You can have 2 cams with same approx dur @ .05 ,lift etc but the cam with a 112 LSA will sound milder at idle and lower engine speeds then the other cam with a 108 LSA.
So mix that with maybe a smaller cid motor too and thats why you heard wicked sounding cams that were smaller spec'd then your's.
SCOTT
SWHEATON is offline
post #10 of 26 (permalink) Old Jan 27th, 11, 11:50 PM Thread Starter
Anhtuan Le
thanks guys, much clearer to me now.
atle is offline
post #11 of 26 (permalink) Old Jan 28th, 11, 9:56 AM
Mark
Give Mike Lewis @ Wolfplace a call:
A nice cam is race-only.
A mild cam is primarily strip but might see some street action.
A "weenie" cam is suitable for the street but some would consider it on the edge.
I don't think it goes any lower than "weenie" for Mike.
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Xtreme70SS396 is offline
post #12 of 26 (permalink) Old Jan 28th, 11, 5:22 PM
Frank Riley
more lift & duration....
70-454 LS5
Mid America Chevelle Club #293
Greater Kansas City
70-SS454 is offline
post #13 of 26 (permalink) Old Jan 28th, 11, 6:17 PM
Originally Posted by Yellomalibu View Post
Nice.
Yup!
Two Lane is offline
post #14 of 26 (permalink) Old Jan 28th, 11, 6:50 PM
I had a "fellow" member here call a mild 223/231 @.050 cam by Harold "wimpy"
Wimpy in my mind is the 396 L35 or L48 350 cam (about 198-204@.050)
mr 4 speed is offline
post #15 of 26 (permalink) Old Jan 28th, 11, 10:51 PM
The other thing to consider in how people categorize mild to radical: comparison.
If my cam is bigger than your cam, yours is mild.
If my cam is smaller than your cam, yours is radical.
