Where to find information on TRW pistons? - Chevelle Tech
post #1 of 9 (permalink) Old Oct 21st, 03, 1:46 AM Thread Starter
Post
I have had in a box in our coat closet for several years (gotta appreciate a wife that lets you keep car parts inside the house ) a set of forged TRW pistons part # 7053P. They are 0.060 454 pistons and I believe for open chamber heads. I purchased them as hand me downs from a friend several years ago with plans to use them on my next engine project, or for when I blow up my flat-top 454. Anyway, I have searched the web and Federal-Moguls website and cannot find any information about them. However, I believe they are the same piston as the now Speed Pro part # L2465f60. Anyone have any ideas how to verify this assumption? Here's a picture:
Thanks,
Tim McNaught<br /><br />1971 Chevelle 454, bench seat 4-speed (original), 4:10's, first car I ever owned, 19 years now.<br />"Cops are gearheads...er...people, too"
tbmc 96 is offline
post #2 of 9 (permalink) Old Oct 21st, 03, 1:49 AM Thread Starter
Post
Oops, wrong button [img]graemlins/clonk.gif[/img]
tbmc 96 is offline
post #3 of 9 (permalink) Old Oct 21st, 03, 8:44 AM
Mr Bill
Post
Tim,
Your machine shop should have an interchange book. That number is an older Speed Pro number, before they consolidated and started using the "old" TRW numbers. If they cant help you, I will see if I have a minute to look it up for you when I get to the shop.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
Team Chevelle #100
BillK is offline
post #4 of 9 (permalink) Old Oct 21st, 03, 12:02 PM
Post
Tim,
I think it's the LS6 replacement. Closed chamber 11.0 piston. I believe it is a press fit pin piston.
Try L2349F & see if it isn't the same
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
----John Wayne----
Wolfplace is offline
post #5 of 9 (permalink) Old Oct 21st, 03, 3:20 PM Thread Starter
Post
Thanks Bill and Mike for your replies. Mike you were right. Since I couldn't find any info on the web, I simply called FM and got through to a person right away. So it took about a minute phone call, and I spent over an hour on the web, [img]graemlins/clonk.gif[/img] .
Next questions, since they are LS6 style closed -chamber pistons, how well will they work with 781 heads. I know they were ran together before with the 781's currently on my motor, as I bought the package deal from a friend. However, would this be asking for trouble or any other issues?
tbmc 96 is offline
post #6 of 9 (permalink) Old Oct 21st, 03, 8:56 PM
Post
They should work very well. About 10.0 with a 119cc head but as I recall you need to check the dome for clearance around the edges as they are designed for a closed chamber head. Should be fine but checking is a good idea.
Just put some clay on the dome & turn the engine over to be sure you have at least .040 or more. If not a little massaging is in order
The easy way is to put the head on with no gasket & see if it clears everywhere assuming you are using a std FelPro .040 gasket.
Mike (Wolfplace)
VISIT US AT
----John Wayne----
post #7 of 9 (permalink) Old Oct 22nd, 03, 6:40 PM
Post
I have an old catalog that list them as open chamber heads only with a 270 dome for a 454 compression is 11.34/100.9 cc 10.69/106.9 cc
10.44 /100.9cc 9.78/116.9 cc 9.60/ 124 cc and has a pressed pin hope that helps
88502 is offline
post #8 of 9 (permalink) Old Oct 23rd, 03, 7:38 AM
Darren
Post
The 7053P are the same as the TRW L-2349F. It is a forged duplicate for the factory 1970 LS-6 piston (11:1 cr with closed chamber heads).
This is a closed chamber piston but will work with open chamber heads. Standard bore has a .265" dome(30.6cc). A .030" over bore piston has a .221" dome (29.4cc). The .060" over bore piston has a .210" dome (27.9cc). This info comes from an old Speed Pro catalog. Hope this helps.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
71454Chevelle is offline
post #9 of 9 (permalink) Old Oct 24th, 03, 1:56 AM Thread Starter
Post
Thanks for all your help. You guys definitely covered my question. Isn't this a crazy hobby...my current combination only has a few hundred miles on it, and I'm already contemplating my next combination .
tbmc 96 is offline
