Nylon Oil Gauge Tubing Kinked - Chevelle Tech
post #1 of 34 (permalink) Old Oct 7th, 10, 10:44 PM Thread Starter
Travis
I was routing this nylon tubing and it got bent, and was creased not cracked.
Is it still safe to use the creased area is laying straight and is inside the car under the dash, I was going to tape the area like 2 inches on either side of it with that aluminum duct tape for A/C ducting.
Is this a viable solution I have no other ferrules, has this happened to anyone of you or people you know of?
1970 Chevelle
SHINER is offline
post #2 of 34 (permalink) Old Oct 7th, 10, 10:53 PM
"Wild Bill"
Re: Nylon Oil Gauge Tubing Kinked
Nylon tubing...as in oil pressure gage tubing?
I wouldn't use that crap...kinked or not. Unless you like hot oil bath treatments.
Copper or braided line only!
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #3 of 34 (permalink) Old Oct 7th, 10, 10:55 PM Thread Starter
Travis
Where can I get copper or braided to fit the back of my aftermarket sunpro gauge?
1970 Chevelle
SHINER is offline
post #4 of 34 (permalink) Old Oct 8th, 10, 1:43 AM
Rod
any auto parts store has the kit, it comes with the ferroules and tubing.
9 years and FINALLY she's drivable, just in time for my first born son.
My_two_tone_'64
Rod Hill
IT/AG instructor
Ag. Mechanics, Ag. Power Mechanics, Ag. Wood
Los Banos High
Los Banos California
twotone64 is offline
post #5 of 34 (permalink) Old Oct 8th, 10, 7:21 AM
Vinny Vince
I know guys do it, but the copper lines scares me more...just too suseptible to kinks and bends. I like the braided stuff too. But, been running the nylon for years and havent had an issue. Just make sure it doesnt contact anything. I actually put some wire loom over it. Will probably go braided at some point.
*11 C6, 6.2, 6spd
69-CHVL is online now
post #6 of 34 (permalink) Old Oct 8th, 10, 7:53 AM
The Fat Stig
skip the gauge with the tubing and go straight to one that uses input from a block sensor
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Automotive Archaeology
Andy69 is offline
post #7 of 34 (permalink) Old Oct 8th, 10, 7:56 AM
If I recall correctly, the fitting at the back of the gauge is for a compression fitting. I used a very short steel tube with a compression fitting on the gauge end and the other end of the tube I used a fitting that converted to NPT - then used a JIC x NPT adapter to use the braided line. A reducing bushing in the block and a NPT x JIC 90 degree elbow to the braided line. Sounds confusing but it's really simple. Take the gauge to a local industrial hydraulics store and they can fix you up.
My Chevelle: http://www.chevelles.com/forums/pict...pictureid=2653
454 +.030 / Lunati 402A3 Cam SFT / 781's / 750 MOD AED Carb on RPM Airgap
/ 200-4R / 3.90 12-Bolt
The Chevelle Club of Michigan http://chevelleclubofmichigan.com
'60's Girls Singing Group: http://www.thewhatabouts.com/
muncher is offline
post #8 of 34 (permalink) Old Oct 8th, 10, 8:56 AM
Buck
The copper lines will wear through way faster than nylon if the rub on anything. we have hundreds of feet of nylon tube on our readymix trucks, and i bet i havent had to replace 2 peices in 30 years I have even seen nylon rub steel and the steel had more wear than the nylon.
Cruzin4Fun
1972 Chevelle
Dakota Digital VHX Gauges
Chris Straub full roller setup.
Retro .510/.492 221/223..108 Sep
Scat Full Rotating assembly
Icon Forged Pistons
http://i994.photobucket.com/albums/a...ps2da74af8.jpg
DONTWANT2 is offline
post #9 of 34 (permalink) Old Oct 8th, 10, 9:42 AM
"Wild Bill"
Over time, the heat from the oil turns the nylon tubing very brittle...like pasta...which then breaks.
Why would you think GM choose to use copper oil pressure line???
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
Heart Of Dixie #231
post #10 of 34 (permalink) Old Oct 8th, 10, 9:46 AM
I have Sunpro gauges in my 70 Sta. Wgn. I used braided Stainless on both my oil press. ( two 70s ) gauges. A 36" B. Stainless cost $28.00 and it will be the last piece you will buy in your lifetime.
Copper & Nylon may work just fine, You may not have a problem.
Braided Stainless is FOREVER.
Is your engine and & interior worth more than $28.00?
Robinls5 is online now
post #11 of 34 (permalink) Old Oct 8th, 10, 9:48 AM
rkd
Ron
For anything more serious than temp use in my cruiser Chevelle, even this poor country boy uses electric senders. The Chevelle came with a cheapo mechanical water temp and oil pressure gage group under the dash, with copper tube, and I have kept them. In the past, I have had an oil pressure line leak, kinda messy at best. I will change these as soon as time and money permit. This may be the reminder I needed...
rkd is offline
post #12 of 34 (permalink) Old Oct 8th, 10, 3:32 PM
Derrick
probably millions of people have put millions of miles on the nylon tubing that comes with gauges without any problems.
is it ideal? probably not.
but it works as long as it is properly installed and kept from kinking and rubbing on metal.
-Hank Hill
novaderrik is offline
post #13 of 34 (permalink) Old Oct 8th, 10, 3:40 PM
Creased = damaged. It's done. Buy new tubing.
Any hardware store or home-improvement center has ferrules. Worst possible case is you buy entire fitting to get ferrules. Best case is you buy 3--5--10 ferrules pre-packaged in a plastic bag.
Schurkey is offline
post #14 of 34 (permalink) Old Oct 8th, 10, 5:34 PM
Chevelle Doctor
Same dang thing we told you in chat last night... I guess you didn't believe us....
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #15 of 34 (permalink) Old Oct 8th, 10, 5:42 PM
Source? TIA!
The Old Reliable is offline
This Thread is more than 2390 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
