454 bored to 496 - Chevelle Tech
post #1 of 18 (permalink) Old Dec 7th, 09, 1:13 PM Thread Starter
james
454 bored to 496
question from someone who is new .... using average upgrade parts .... how much hp and tq. could i benefit from boring out a 454 .... to a 496
1973 bbc
300hp
390lbs of tq
stock
thewolf is offline
post #2 of 18 (permalink) Old Dec 7th, 09, 1:40 PM
Brandon
Re: 454 bored to 496
Cost of parts is the cost of parts, just depends on how radical you want to get with compression and cam. Can easily get 500HP.
71 Chevelle
ATK Engines 496 Stroker
TH400 / 9 Inch 3500 Stall
Full UMI Suspension with Viking Shocks
http://brandons71chevelle.weebly.com/
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
Need an engine...shoot me a PM.
ATK SBC Perf. Cylinder Heads are IN STOCK! 64cc/70cc - 185cc/195cc/210cc
Notalent is offline
post #3 of 18 (permalink) Old Dec 7th, 09, 1:53 PM
& Administrator
And FYI ,you need to bore & Stroke to get 496".
Bore is usually 4.31" and stroke is 4.25" compared to the stock 4.25" bore & 4.00" stroke
Mike is offline
post #4 of 18 (permalink) Old Dec 7th, 09, 1:55 PM
You should have some good heads to start with. If you're going for a strong street toy, you can reuse your rods, get a cast stroker crank and pistons and you'll probably be fine. If you want to wail on it, you'll have to step up to the good stuff. There's a wide range of budgets from used parts to top-end stuff.
Gary Adrian
The correct spelling is
HILLIARY
Busted Knuckles is offline
post #5 of 18 (permalink) Old Dec 7th, 09, 2:58 PM
At the risk of stating the obvious, 496 is about 9.25% larger than 454, so you stand to make about 9.25% more power, all else being equal. The question becomes, does the money spent for the stroker kit give you more bang for the buck than spending the money elsewhere?
Georgia69 is offline
post #6 of 18 (permalink) Old Dec 7th, 09, 3:13 PM
Bryon
I guess that depends on what you are starting with, what your goal is. Another question would be whether or not you are considering nitrous or a supercharger.
I guess I would say starting with a stock engine, you would probably gain the most from heads and intake. Unless the engine needs a rebuild anyway.
Then if you are going to spend the money, a stroker kit would end up costing about the same amount as a normal rebuild - roughly. If you need to bore it, use new pistons anyway and the crank needs to be turned, the gain from the stroker kit would be well worth it.
Red 1967 Chevelle SS 396, 4 speed, 3.31 12 bolt posi, black bench seat interior, Bolero Red - long term restoration project
68 Camaro SS - 468 BBC, 781 heads, RPM Air Gap intake, Lakewood bellhousing, M21, BO coded 12 bolt - but 3.31 posi now. Old drag car, back on the street.
bcmiller is offline
post #7 of 18 (permalink) Old Dec 7th, 09, 3:15 PM
kevin
fwiw....I have a new 496 in my chevelle. it is a bored, stroked and clearanced (6.385 rods) 427 4bolt main block. I run edelbrock op heads. comp cam solid ft xs-290-10 cam.... 10.7:1 cr...makes 607 hp @6100 rpm.....627 ft/lb @ 4500 rpm.....has turned my 67ss("396") into a real beast that needs much larger rear trires.....go for it - and especially so if you need a new crank....you wil not be disapointed...
the heckler is offline
post #8 of 18 (permalink) Old Dec 7th, 09, 4:09 PM
On my 454 core, the crank & pistons were junk, so...pretty much just as cheap to stroke it to 496 as it would have been to build a 468.
post #9 of 18 (permalink) Old Dec 7th, 09, 9:14 PM
Curious as to why most shoot for 496 when a .030" overbore 489 leaves some wiggle room down the road with a seasoned oem block.What if your sonic check does not allow more than 4.310" bore.Seems like the 4.280" would have one more serious build left in it before scrapping the vintage iron.
George
8-71 blown 461 Rat on E-85
ironhead is offline
post #10 of 18 (permalink) Old Dec 7th, 09, 9:48 PM
Bryon
496 just sounds cooler!
bcmiller is offline
post #11 of 18 (permalink) Old Dec 8th, 09, 10:31 AM
Mine wouldn't clean up at .030. Had to go .060. I think most 454's can safely go to .100, based on what I read on these forums, but I'm no expert.
post #12 of 18 (permalink) Old Dec 8th, 09, 1:52 PM
George
many, many 454s have already been punched .030" over hence the popularity of 496s at .060" over.
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is offline
post #13 of 18 (permalink) Old Dec 9th, 09, 12:16 PM
Im not a used piston guy either but what about your crank makes it "Junk"? If your new before deciding on how much CID you need first determine what kind of power you desire. You claimed your 73 block was 300 hp and 390 tq. You dont have to stroke a 454 to easily achieve 500hp and 500 ft lbs and can all be done with a stock crank. Whats the motor going into, what kind of diriving wiht the car see, what trans etc etc. Need the whole picture to detrmine what is going to be your best bang for the buck.
30-A rider is offline
post #14 of 18 (permalink) Old Dec 17th, 09, 11:44 AM
Send a message via AIM to jhunt
Thumbs up Re: 454 bored to 496
I agree, so when I need to do more I can say to the wife that I've gone as far as I can go with this motor so I need to buy a new block. 540 here we come with the wifes approval.LOL
John H
66 SS
498ci, 2 bolt main, 4 speed Muncie-21, Comp cam hyd roller. Duration @ .050 Intake 248/Exhaust 258. Intake 613/613 exh on 114 lobe separation, Dart dual plane manifold,Edl. 100cc heads, 950 HP carb,MSD 6-al.
http://pic20.picturetrail.com/VOL130.../295356440.jpg
http://www.youtube.com/watch?v=toP8BblBkxA
jhunt is offline
post #15 of 18 (permalink) Old Dec 17th, 09, 2:08 PM
Talking Re: 454 bored to 496
Thats what I did
Garry
1975 El Camino Ground-up Resto Done after 12 years! 7-17-07
Scaldinghotelcamino.com
1967 Pro-St Camaro
489ci 622hp @ 6000rpm 593ft-lbs. torque @ 4800rpm on pump gas
Scaldinghot.com
Pro Street Garry is offline
