Ls7 454 - Chevelle Tech
post #1 of 32 (permalink) Old Oct 23rd, 09, 5:22 PM Thread Starter
Ls7 454
does anybody know the cam specs for a LS7 454 or know where i can find them?
deadpool1988 is offline
post #2 of 32 (permalink) Old Oct 23rd, 09, 5:28 PM
LS7
LS7 is offline
post #3 of 32 (permalink) Old Oct 23rd, 09, 5:32 PM Thread Starter
Re: Ls7 454
thanks for the information i needed
post #4 of 32 (permalink) Old Oct 23rd, 09, 6:00 PM
LS7
Re: Ls7 454
You're welcome. And welcome to Team Chevelle Jeff.
LS7 is offline
post #5 of 32 (permalink) Old Oct 23rd, 09, 7:20 PM
Michael
Send a message via AIM to MEJ1990TM
Re: Ls7 454
For some reason I was thinking they came with the same cam as the LS6's. Guess I was wrong.
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
MEJ1990TM is offline
post #6 of 32 (permalink) Old Oct 23rd, 09, 9:11 PM
George
Re: Ls7 454
3959180 - Mechanical Flat Tappet
This mechanical flat tappet is a ZL-1 and LS-7 mechanical lifter competition cam, good in 427-454. (Use spring P/N 3916164.) The duration at lash point in degrees (intake/exhaust) is 327/333; duration at .050" tappet lift (intake/exhaust) is 262/273; and maximum lift with 1.7:1 rocker ratio (intake/exhaust) is 580/620. Valve lash is .024/.026 and lobe centerline is 110 degrees.
Technical Notes: Distributor P/N 1104067 or melonized distribuor gear P/N 1045613 must be used on all crate engines with steel camshafts.
Hmmmm, remembering the specs as somewhat different that this .580/.600 lift.....
I helped a pal put the crate engine PN 774 in his 70 SS Chevelle. OMG, what a BEAST!
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is offline
post #7 of 32 (permalink) Old Oct 26th, 09, 1:25 PM
Re: Ls7 454
1970 SS 454 LS-7
Adrian D. is offline
post #8 of 32 (permalink) Old Oct 26th, 09, 3:03 PM
George
Re: Ls7 454
OK, .560/.580" does sound better to my memory than when I wrote .580/.600" the other day
Not sure what cam "LS7" and his sources are looking at in Post #2? Engineering does change specs from time to time....
George Kettler
kettbo is offline
post #9 of 32 (permalink) Old Oct 26th, 09, 3:07 PM
Kyle
Send a message via Yahoo to justkyle
Re: Ls7 454
I wonder how well that cam would work in a 496?
Kyle
70 malibu race car
How to build a proper TFH
justkyle is offline
post #10 of 32 (permalink) Old Oct 26th, 09, 5:14 PM
LS7
Re: Ls7 454
George, the numbers in my link are correct.
You will notice that there are two different lift specifications in those two articles that Adrian posted.
The first article (lower left) has the correct numbers minus the specified lash.
LS7 is offline
post #11 of 32 (permalink) Old Oct 26th, 09, 5:30 PM
LS7
Re: Ls7 454
Maybe the .560 and .600 numbers you keep refering to are measurements taken @ .015".
http://www.geocities.com/MotorCity/D...00/cmspec.html
2. Any value in parenthesis ( ) is calculated. All lobe centers and distance between lobe centers are calculated. These are not advertised values. As such, they may be inaccurate due to lobe ramps ground non-symetrically.
If mechanical, deduct lash from lift to get actual lift at Valve unless marked as @ .015".
http://books.google.ca/books?id=seOU...mshaft&f=false
In the above link you will also notice on page 55 that the '143' LS6/78/72 cam is listed as .500 lift when it is commonly known to many as a .520 lift.
It all depends on where it is being measured.
LS7 is offline
post #12 of 32 (permalink) Old Oct 26th, 09, 5:43 PM
LS7
Re: Ls7 454
Copyright 2000 General Motors Corporation.
LS7 is offline
post #13 of 32 (permalink) Old Oct 26th, 09, 10:48 PM
Michael
Re: Ls7 454
What kind of street manners would a factory cammed 12:1 LS7 have?
post #14 of 32 (permalink) Old Oct 26th, 09, 11:21 PM
Larry
Re: Ls7 454
I would never use that old technology. I built a flat tappet 468 with oval port heads on it that made 670 h.p. right after an LS-6 made 452 h.p. on the same dyno. The torque on my motor was 632 and the torque on the LS-6 was 520. I think camshaft technology has came a long ways since the seventys, even with the flat tappet stuff. Granted mine had a little more compression and good port work in the heads but I bet I had less money in my motor than the guy had in the LS-6, he payed someone to go thru his. I've been in a car in the past that had and LS-7 in it with a roller cam and I can tell you that thing was a pussy cat compared this thing.
westexun is offline
post #15 of 32 (permalink) Old Oct 26th, 09, 11:24 PM
Michael
Re: Ls7 454
Was it a true to form LS7 that was 12:1, rectangular port open chamber heads, with the bigger solid flat tappet?
