#5 cylinder not firing - what are my options? - Chevelle Tech
post #1 of 13 (permalink) Old Sep 29th, 09, 3:42 PM Thread Starter
Caleb
I took my car in to get a second opinion on a compression test and got some very bad news. my compression ended up being much higher than I was originally told (good news), but my #5 cylinder is not firing (not so good news).
the mechanic showed me by pulling the #4 wire off the distro cap and hearing the difference when it was connected vs unconnected. then he showed me #5, which had no difference either way.
it probably looks like I need an engine rebuild or a new engine (it's a toss up right now), but don't have the funds yet.
What are my options right now? I just want to cruise until I can afford a rebuild/new engine. What harm will be caused with a cylinder not firing? How often should i change my oil, now that fuel is probably leaking into my oil pan?
Let me know what ya'll think.
caleb.
bornyellow is offline
post #2 of 13 (permalink) Old Sep 29th, 09, 4:17 PM
& Administrator
Re: #5 cylinder not firing - what are my options?
Swap a plug wire from one that's firing and see if the 'not firing' follows the wire.
If it does ,get new wires.
Pull the plug on #5 and have a look see.
Might swap plug same as wire to see if that moves the problem.
If it does get new plugs.
If those don't work ,pull the valve cover and see if the rockers on #5 are moving the same rate as the others.
Mike is offline
post #3 of 13 (permalink) Old Sep 29th, 09, 4:20 PM
Doug
What was the compression in the cylinder not firing?
70 SS 454 LS-5 M-22 Bornwith Drivetrain-Sold New Baldwin Chevrolet
72 SS 454 El Camino W Code-427 4spd.
60',1.46, 6.63@103.59 10.45@128.1
My Showroom
https://www.youtube.com/watch?v=MQuBitMOA5w
Resto Pics http://www.chevelles.com/forums/35-r...tion-pics.html
DougA is offline
post #4 of 13 (permalink) Old Sep 29th, 09, 4:47 PM
Rich
Didn't the mechanic you were talking to give you some idea of why that cylinder wasn't firing? Did he perhaps suggest what to do to fix it?
Probably in the plugs, wires or distributor cap. You could probably replace them all for less than $100. If the cylinder has compression it's not a bad valve or bad rings so that's a good thing. One misfiring cylinder doesn't necessarily mean you need a rebuild.....
Rich-L79 is offline
post #5 of 13 (permalink) Old Sep 29th, 09, 5:04 PM
Many things can cause a cylinder to not fire, especially at idle. As stated above, pull the plug on #5 and see what you got. If it is oil-free, it should not take much to get it going again. Check for vacuum leaks , such as a bad gasket or maybe a vacuum hose on the #5 runner that is leaking. Swapping the plug and wires is certainly a cheap and effective way to start.
JWagner is online now
post #6 of 13 (permalink) Old Sep 29th, 09, 5:23 PM Thread Starter
Caleb
Thanks for the suggestions.
within the last 200 miles i've replaced the
- distro cap and rotor
- upgraded wires to 8.5
I believe the test yielded zero compression, but I'll call to make sure. the shop suggested it might be a warn camshaft lobe. i'll swap plugs, and see how that goes.
post #7 of 13 (permalink) Old Sep 29th, 09, 5:45 PM
& Administrator
You might have mentioned that you had 0 compression in your 1st post.
All you said was
but no other info.
Mike is offline
post #8 of 13 (permalink) Old Sep 29th, 09, 5:46 PM
Rich
Well, that's a whole different ball game. If cylinder #5 has no compression, no amount of ignition parts will fix that problem. First you stated it had compression now you say it does not. Which is it? The route to fixing things is a WHOLE lot different depending on whether that cylinder has good compression or not.
Rich-L79 is offline
post #9 of 13 (permalink) Old Sep 29th, 09, 6:04 PM
& Administrator
OK ,back to what I said earlier
It'll make a difference if it's the intake or the exhaust as to any further damage.
If the intake isn't working ,they'll be less flow of air/fuel into the cylinder so less cylinder washdown.
If it's the exhaust, the engine will be fighting the compressed air/fuel as it's got nowhere to escape.
Also keep in mind that if you've wiped a cam lobe or 2 ,that you now have metallic debris floating around the inside of the engine - not good.
Keep us posted.
Mike is offline
post #10 of 13 (permalink) Old Sep 29th, 09, 6:53 PM Thread Starter
Caleb
sorry for the confusion, the first shop that ran the compression test told me it was 75-80 psi, on all cylinders. i thought that was pretty low so i brought it to another shop and said my compression is 120 psi for most of them...one was 110, and Johnny #5 was not not alive.
**just called the shop and they said #5 still had compression at 120psi and it did indeed have spark**..so i guess i won't be swapping plugs.
if it's the camshaft lobe...that's bad. I'll have to pull the valve covers to check.
thanks for all the suggestions so far....any other suggestions?
post #11 of 13 (permalink) Old Sep 29th, 09, 7:33 PM
MORE than enough to make the cylinder run; although not as much as you might want it to have. I like ~150 as a minimum.
WHERE did it have spark? At the plug end of the wire?
A fouled plug, or one with a damaged porcelain (cracked, for instance) will still cause a dead cylinder even if the wire leading to it has spark.
You have compression, you (probably) have spark. After verifying the condition of the plug, you'll be looking for the vacuum leaks as previously suggested.
Although the camshaft/rockers may be going bad--if you have compression the cylinder should run. Valvetrain is not the first thing I'd be checking, here.
Schurkey is offline
post #12 of 13 (permalink) Old Sep 29th, 09, 8:21 PM Thread Starter
Caleb
i'm checking my notes from my first shop and they said
nox system unit removed and vacuum hoses need to be hooked up correctly
also mentioned in my notes are
the PC system needs the right pcv valve and hose
i have no idea what this does.
oh look at this...found at the very end of my notes
needs to repair vaccum leaks
interesting. I'm going to have to take a look at this. fingers are crossed, I hope the vacuum leak is the problem.
THIS SITE HAS BEEN AWESOME!
thanks everyone.
post #13 of 13 (permalink) Old Sep 29th, 09, 8:30 PM
joe
I think you should of bought a compression gauge for $30 bucks and saved yourself some time and money. If you don't know how to check your compression then, that's when this site comes in handy and we/somebody will walk you through it. Just a thought. But if you have 120psi, thatís more than enough pressure to fire that johnny boy unless you wiped the cam. Yup time to pull the Valve cover.
tonkas69 is offline
