How to read a cam grind number... - Chevelle Tech
post #1 of 15 (permalink) Old Feb 2nd, 09, 8:28 PM Thread Starter
Shane
I am looking for a cam and am curious as to how to read a grind/part number at the end of the cam...
How to read...
Lunati...
Comp...
Crane...
What is the part number?
What is the grind number?
fishhead is offline
post #2 of 15 (permalink) Old Feb 2nd, 09, 10:22 PM Thread Starter
Shane
Re: How to read a cam grind number...
OK I think I found some specs on a cam that I am interested in...
BBC 454...
I am busy schooling myself on what the numbers mean and how you get intensities etc...
224/234
.525/.550
but whats the 114CL mean?
Still readin...
fishhead is offline
post #3 of 15 (permalink) Old Feb 2nd, 09, 10:31 PM
Greg
The grind number gives you the basic cam info. Like the Crane 274HO6-tells you the adv. duration is 274 degrees, H is for hydraulic, an 06 tells you the lobe separation angle of 106. Part number is 100172 which really tells you nothing. The cam companies all have their own "grind numbers". Some actually give you some cam data, others do not make too much sense. Some of Isky's grinds are somewhat informative like the 280 Mega Hydraulic tells you it has 280 degrees of duration but that is about it. An Isky RPM 300 cam does not really tell you too much and usually this cam is 270 duration, 228 @ .050 duration, on a 108 LSA. You really need to look at the cam card to find all the specs on the cam and sometimes what is stamped on the end of the cam may not give you too much info. I once had a Melling cam I ordered for a Pontiac motor but when I looked at the end stamping it cross referenced to a big block chevy cam. I called Melling and they said to send it back for them to check it out. It was a Pontiac cam but he said sometimes the stamp numbers may not give you the right info!!
docwilcar is offline
post #4 of 15 (permalink) Old Feb 2nd, 09, 10:47 PM Thread Starter
Shane
I am going to pick a cam and call someone at the company and see what info I can find out that way...
Does anyone have a good website for reading about camshafts???
I understand what each section of the lobe does and how it works in conjunction with the carnk via the timing gears...just need to figure out how the numbers work now...
fishhead is offline
post #5 of 15 (permalink) Old Feb 2nd, 09, 11:05 PM
Greg
The 224 means the duration at .050 on the intake, 234 is the .050 dur. on the exhaust, .525 and .550 are the intake and exhaust valve lifts. The 114CL could mean either the intake center line of the cam lobe is installed 114 deg. after top center or more likely it is refering to the lobe serparation angle which is the angle between the maximum lift point( or center) of the intake lobe and the max. lift point on the exhaust lobe. A wide LSA like 114 usually gives a broad power range, smoother idle, and increased high rpm power. A tight or lower LSA usually like 106-110 will usually give better low and midrange power but is more "peaky" and comes on with more of a bang but the higher rpm power falls off more quickly. A tight LSA cam usually has a rougher idle due to increased overlap( given the same cam specs except for the LSA change) and does not make as much vacuum as the wider LSA cam. Intensity if found by subtracting the .050 duration from the advertised duration. A 270 adv. duration with a 220 .050 duration would have a hydraulic intensity of 50. Another modern fast lobe cam might have an adv. duration of 270 but an .050 duration of 230 or have a 40 intensity. The lower the intensity number the quicker the valves open and close as I understand it. Am sure there is a lot more to it than that but gives you some idea.
post #6 of 15 (permalink) Old Feb 2nd, 09, 11:38 PM Thread Starter
Shane
Got it...
A big thanks...
this isnt a street cam is it?
fishhead is offline
post #7 of 15 (permalink) Old Feb 3rd, 09, 11:31 AM
Greg
A very good book on cams is the one by David Vizard, one of the best SBC authors. The book is Chevrolet Small-Block V-8 Camshafts and Valvetrains. This is a Powerpro Series book and is available through amazon for around $20. Very informative book on cams.
post #8 of 15 (permalink) Old Feb 3rd, 09, 11:38 AM
Craig
Hello,
If you go to the Comp. Cams website they have a program there that you can enter all your vehicle info into ie.. weight,gear ratio,compression of motor,and so on. By using this program they will show you the best cam grind for your application. Its worth a try to do this to get a good idea of whats availible for your set up, Just my suggestion,good luck
Craig
70' ElCamino 414 BBC,781 heads stock valves bowl blend and port smooth,1.7 rollers,7/16 push rods,Straub Tech custom Hyd. Roller,Speed pro +.060 with .319 dome,MSD,Holley 850 vac sec.Edl Air Gap,130GPH Holley mech fuel pump,ARP head/main studs,7/16 rod bolts,Tremec TKO600 5 speed with .82 overdrive gear,Quick Performance 9",True trac posi 3.50ratio,DM rear adj. arms,Ground up disc brake conversion, serp belt drive and more...
costtxcamino is offline
post #9 of 15 (permalink) Old Feb 3rd, 09, 2:12 PM
Aaron
high performance camshafts and valvetrain by SA designs/Cartech books..
i bought mine at borders in whitehall... about 18 bucks.
pick one up. very good book, helps you choose the right one, gets down to the math involved in designing and explains everything you need to know about a cam.
aaron
1971 Chevelle. 355, megasquirt efi. On3 7875 turbo. 4l80e, py3600, 355 gears. C5 brakes, SC&C stg2+, hellwig bars, 04-06 gto seats. 546rwhp/450rwtq with 28% converter slip on 18psi!
Little walk around video
http://youtu.be/D_B0B1RNmcc
BowtieAaron is offline
post #10 of 15 (permalink) Old Feb 3rd, 09, 5:09 PM Thread Starter
Shane
A big thanks guys...
fishhead is offline
post #11 of 15 (permalink) Old Feb 3rd, 09, 5:18 PM
Send a message via AIM to Chevyboy_0
Originally Posted by costtxcamino View Post
Hello,
I downloaded that program, it's called camquest it's a very helpful program because it gives you choices for just about everything, such as carb or FI and forced induction head style what kind of idle you want and slot of other stuff. I thought it was quite helpful. The best part is that it's free
ALMYDOE V2.0 Coming soon
1: 1970 Chevelle SS-clone "ALMYDOE" Holley 4bbl, GMPP intake, Summit Racing Gear Drive, American Racing Rims, Flowmster Exhaust , DuPont Blue,
Stock 12 Bolt w/ 2.73
2: 2000 Chevy S10, 2.2/Auto, 16x8 rims, Spectre CAI. Low and slow but cheap!
Chevyboy_0 is offline
post #12 of 15 (permalink) Old Apr 29th, 16, 11:22 AM
I have a cam but don't know what grind it is,the numbers on cam are 6245/6215 then it has a 56,also has J 4500-06 can you help me out THANKS
nhr-16 is offline
post #13 of 15 (permalink) Old May 1st, 16, 10:25 AM
Bill R
Grind numbers don't always contain information related to the camshaft's specifications - depending on the manufacturer. Often times it is difficult or even impossible to determine who the cam manufacturer is and to get creditable information regarding the cam's specs. Just another of many reasons NOT to buy a used camshaft . . . . . . .
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (25+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
engineguy is offline
post #14 of 15 (permalink) Old May 1st, 16, 1:27 PM
Vince
is it new or used?
is it a Jones cam??
VinceS427bb is offline
post #15 of 15 (permalink) Old May 1st, 16, 3:32 PM
Chevelle Doctor
Is it a roller or a flat tappet core? Measure the sides of a lobe, then the height of a lobe, subtract the small number from the higher number. See how close it is to 330.
Dave Birdwell is offline
