Rear main seal replacement effort - Chevelle Tech
post #1 of 9 (permalink) Old Jan 25th, 08, 9:25 AM Thread Starter
I have a small leak from the rear main seal on my early 70's big block. I will be doing an auto to 5speed conversion, so everything should be cleared out back there. How hard would it be to replace that seal, remove the oil pan, flip the motor and all that? I understand that there are one piece and two piece seals, I have no idea what mine is.
68 SS front, 68 SS rear
zz502 and Hydroboost, Underside TKO,
Short stick console
YouTube video
I'm not a car guy but did all the mech/elec work... and everything started with a dumb question
gibbons is offline
post #2 of 9 (permalink) Old Jan 25th, 08, 9:43 AM
Dave 383 now
Re: Rear main seal replacement effort
You have a 2 piece. Its easier to do on a engine stand but you can do it in the car.
Dave427 is offline
post #3 of 9 (permalink) Old Jan 25th, 08, 11:17 AM
Darren
Honestly, I'd pull it. Since you're doing the 5 speed swap, it's going to be that much easier getting the bellhousing dialed in correctly with the engine out of the car. Not to mention getting the pan off and back on good, with no leaks. Drop the engine back in with the clutch and bellhousing on and dialed in, and you're almost done.
Darren
64 El Camino 468, 9", ST-10, 4wdb, eternal project
69 Firebird 461" stroker, th400, 3.36's, 4wdb, Midnight Green - Sold
Beach Cam
TC #78 Gold, ACES #3130
Cameano is offline
post #4 of 9 (permalink) Old Jan 25th, 08, 11:33 AM
Matt
Are you positive you have a rear main leak? Change the valve cover gaskets just to make sure?
bochnak is offline
post #5 of 9 (permalink) Old Jan 25th, 08, 11:38 AM Thread Starter
Yikes, I knew this wouldn't be fun... I am not like you guys with engine hoists and stuff. I did disc brakes and set up a rear end, but I don't feel like yanking out the motor. I can do like I did on my 92 F-250 that has had a rear main leak since new: Take two paper towels, roll them into a tight cylinder, and stuff them between the scattershield front plate and the oil pan with a screwdriver. Replace the papertowels each oil change. Done.
Short stick console
YouTube video
gibbons is offline
post #6 of 9 (permalink) Old Jan 25th, 08, 1:33 PM
Dave 383 now
Oil on a new clutch sucks,,,Dave
Dave427 is offline
post #7 of 9 (permalink) Old Jan 25th, 08, 1:58 PM Thread Starter
I guess I will fully discover the source when I take out the TH400. Nothing is easy, is it.
Short stick console
YouTube video
gibbons is offline
post #8 of 9 (permalink) Old Jan 25th, 08, 2:31 PM
Tim
It never is...starting to wonder why I bought a chevelle again.
The mighty hand of vengeance sent down to strike the unroad worthy.
1965 Chevelle SS - Numbers matching
www.bicyclechronicles.com
djshakes is offline
post #9 of 9 (permalink) Old Jan 25th, 08, 4:45 PM
Jonathan
Pull the engine, follow the instructions to the letter using the "shoehorn" supplied in the kit. Don't hurry. If you damage the seal buy another one. Don't gamble that it won't leak because it will. While it is out replace the VC gaskets too. Also give you a good chance to examine the intake gasket.
Chevelles are easy to work on compared to smog laden newer cars.
You will be just fine.
https://www.coolharts.com
http://www.carolinachevelle.com/
72 Chevelle Malibu
72 Chevelle Malibu In Process
NCOA #6446
ACES #8153
Carolina Chevelle Association #147
Maryland Chevelle Club #834
Chevelle_Nut is online now
