January 70 date code on 71 CLB block?? - Chevelle Tech
post #1 of 1 (permalink) Old Jan 19th, 08, 11:42 PM Thread Starter
Hello, I have a January, 26 1970(A 26 70) date coded 3969854 402 block with a T0819CLB(august,19th) code on the front pad w/11S105170 also on pad. Heads are 3993820 date coded June,28 1970(F 28 70). Was this block just sitting arond for 8 months before use? The aug, 19th date and the 105170(last 6 of VIN?) shows a very early 71 model, correct? Just wondering if anyone else has seen this large of a span between casting date and actual production use? Thanks.
69SS3964Spd is offline
This Thread is more than 3417 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
