piston to head clearance - Chevelle Tech
post #1 of 5 (permalink) Old Jan 16th, 08, 2:49 PM Thread Starter
brian
Question piston to head clearance
i have 396 .30 over l2287 closed pistons and 115cc aluminum open chamber heads, no decking .039 gasket. will domes clear the chambers? the motor is together but not fired. do i need to use a cam button with a thumpr roller cam if i use a front bearing? people have brought up these issues to me. any help would be great
thanks brian
bjgoodrum is offline
post #2 of 5 (permalink) Old Jan 16th, 08, 4:58 PM
Re: piston to head clearance
if it turns over with the heads bolted down it's probably ok.
you need a cam thrust button properly installed to keep the cam from moving forward in the block. this is required on retro-fit roller cams. this is not optional.
Is that one of the CC cast iron roller cams?
post #3 of 5 (permalink) Old Jan 16th, 08, 5:09 PM Thread Starter
brian
its a comp cam mutha thumpr hydraulic roller i dont know if it cast iron or billet
post #4 of 5 (permalink) Old Jan 16th, 08, 6:39 PM
I guess since it's already together it's too late to check. But my 2287 pistons in a 781 casting open chamber head hit the sides of the chamber. But I do all my clearance checks without a gasket. That way I know if it clears without the gasket, it'll be fine with the gasket.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #5 of 5 (permalink) Old Jan 16th, 08, 7:13 PM Thread Starter
brian
i turned the motor a full turn. it turned freely, the valves are not set though. it wouldnt turn if pistons were hitting side of chamber, right?
