Gen V 454 oil pressure switch - Chevelle Tech
post #1 of 8 (permalink) Old Oct 19th, 07, 4:01 PM Thread Starter
Ray
I just bought a rebuilt Gen V 1991 454. I notice that there are two holes on the passenger side of the block above where starter would mount. These holes will accept 1/4" plugs. I tried to push a dowel in each one to see if it went all the way through. It does not. Does anyone know what these two holes are for? Should I just put 1/4" plugs in them. Also on the 1991 Gen V 454 where does the oil pressure switch go? Any help is appreciated. Thanks.
Ray (NJ)<BR>72 BB Chevelle<BR>A.C.E.S #3750<BR>T.C. #850
RaySky is offline
post #2 of 8 (permalink) Old Oct 19th, 07, 4:06 PM
Vince
Re: Gen V 454 oil pressure switch
i believe the holes are for the external oil cooler lines that run to the radiator side tank.
VinceS427bb is offline
post #3 of 8 (permalink) Old Oct 20th, 07, 3:26 PM Thread Starter
Ray
If that is what they are. would that mean, if I'm not using a cooler they would need to be plugged?
RaySky is offline
post #4 of 8 (permalink) Old Oct 20th, 07, 4:02 PM
Bryan
They are blind holes, don't worry about them UNLESS you plan on using a set of Sanderson Cast Iron Block Hugger headers. If this is your intent>>>get out the grinder and grind the bosses off.
These headers fit extremely close to the block (mini starter highly reccommended)
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
Bryan59EC is offline
post #5 of 8 (permalink) Old Oct 21st, 07, 10:59 AM Thread Starter
Ray
o.k seems like I don't have to be concerned about them. Where do you guys using this block hook up your oil pressure gauge?
RaySky is offline
post #6 of 8 (permalink) Old Oct 21st, 07, 3:28 PM
Vince
i'm sorry i was reading the Driver's side for some reason?????????
there should be two pipe plugs or cooler lines on the drivers side of the block and you could run your pressure gauge to there....
post #7 of 8 (permalink) Old Oct 23rd, 07, 9:28 PM Thread Starter
Ray
Thanks.
RaySky is offline
post #8 of 8 (permalink) Old Oct 23rd, 07, 11:16 PM
Bryan
pipe plug just above the oil filter boss
pipe plug at the very front of the block on the driver side.
Bryan's toyz
