Tuned vs Non Tuned Headers - Chevelle Tech
post #1 of 20 (permalink) Old Jan 31st, 07, 1:08 PM Thread Starter
Frank
Question Tuned vs Non Tuned Headers
Hi Guys,
I read the recent thread on ceramic headers. Considering the responses, I have decided to do the jet hot route. Now for the question. The tech at jet hot said for street use I would not notice a difference between a tuned header and a non tuned. I am not planning on racing so this is for street use and ocassional hot rodding. I am going with 2" primaries with a 3 1/2" collector. Also I am leaning toward the Hooker brand. Super Comp ( which is tuned ) and the Comp. obviously non tuned. Difference in price is 200.00 between the 2. So will I see a 200.00 difference in preformance?
Thanks in Advance.
Frank
66 SS Big Block
66 SS Big Block is offline
post #2 of 20 (permalink) Old Jan 31st, 07, 1:14 PM
Re: Tuned vs Non Tuned Headers
Equal Length headers ..... On the street thru the mufflers .NO !!!
2" primary is pretty big do you have a 550hp motor or more ?/ if not go for 1 3/4 to max 1 7/8" primary pipe and I like a 3" collector .the smaller sizes will build velocity / heat and make more torque down low ...... Hedman makes a very nice fitting header on early BB chevelles with 3" collectors ......do a search you will find lots of info on headr sizing .....sizing all based on your engine HP and end use
Was 439ci Straub Solid Roller Brodix RR, SOLD
,Tremec by Liberty
10.97/ 124.31 1.41 60ft
New Foxwell Power Coming
Crusin / Track video http://www.youtube.com/watch?v=fhvDGOO4JAI
Engine
CDN SS is offline
post #3 of 20 (permalink) Old Jan 31st, 07, 2:00 PM
Both headers are somewhat "tuned". I believe the selling point on the super comps was that the tube were within 5% length of each other while the comp headers are 10% length of each other. Will you notice a difference no. Probably an easier fit with the comp headers.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #4 of 20 (permalink) Old Jan 31st, 07, 2:15 PM
chris
Good advise from CDN SS.
1969 ls7 ls resto...re-creation.
Chris Stanwyck is offline
post #5 of 20 (permalink) Old Jan 31st, 07, 9:21 PM
Talking Re: Tuned vs Non Tuned Headers
Frank,
A set of 1 3/4" primary long tube headers will work just fine for a street car.
I like using DynoMax and Hedman myself. Hookers are way over priced IMO.
Good Luck!
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Rat Muscle Parts Hauler)
1967 C10 Short-Wide 489BB/TH400/12-bolt (The Future Shop Truck)
2008 Harley Davidson Dyna Low Rider (Stress Buster)
2015 Harley Davidson Road Glide Special (Cruiser)
2015 Chevy Silverado RS Edition (Daily Driver)
My Chevelle: http://www.chevelles.com/feature/nov98.html
C & D Performance
North Texas Chevelles
Motorhead62 is offline
post #6 of 20 (permalink) Old Jan 31st, 07, 11:29 PM Thread Starter
Frank
Hi Guys,
Thanks for the responses. I will look into it a little more. The car is a 375 Horse with the square port heads. It does have a cam in it so lets say between 375 and 400 althought the 375 in 65 was rated at 425. I had a typo on my intial post. The difference in price is 300.00.
Thanks.
Frank
post #7 of 20 (permalink) Old Feb 1st, 07, 8:25 AM
Frank,all you need is 1 3/4" primary 3" collectors for your ride.
You will NOT feel $300 worth of increased performance using anything bigger
mr 4 speed is offline
post #8 of 20 (permalink) Old Feb 1st, 07, 10:23 AM
Originally Posted by 66 SS Big Block View Post
Hi Guys,
Thanks.
Frank
Street 396/375 square port head ....... all the more reason to not go too big, those rect heads dont make a lot of torque down low unless you have 4.10 gears stay at 1 /3/4 max 1 7/8 ...... tuned and equal length are two different things . tuned means just that, tuned to the application and end use . street with street gears you want torque down low in rpm range and also collector sizing is very overlooked in chosing a header ...... tuned for your use and engine is smaller primary like 1 3/4 and collector 3" and if you really anal collector length ....... I like the hedman since they one of few mfg. who make an off the shelf header with 1 3/4 with 3" collector .....suggestion if you want max tune use 3" exhaust pipe from header to muffler then 2 1/2 tailpipes FWIW
,Tremec by Liberty
Engine
CDN SS is offline
post #9 of 20 (permalink) Old Feb 1st, 07, 10:27 AM
Bill R
The term "tuned headers" is a marketing term and is about as outdated and non-descriptive as categorizing cams as "3/4 Race and Full Race".
A "tuned header" usually describes a header that has equal length (or nearly equal length) primary tubes. We all know that primary tube diameter, tube length and collector design all go into the receipe for a tuned header. Now, the chore here is to get the header "tuned" to the RPM at which the engine makes the most horsepower. A "tuned" header is actually in "tune" during a very short RPM band. (This RPM band is even shorter in a high RPM Pro Stock of Competition Eliminator class car.)
In summary - no, a "tuned" header is not at all necessary in a street or street/strip application. This is because a steet or street/strip vehicle needs to produce HP and torque throughout a wide RPM band, therefore the header would be in "tune" for a very minimum amount of time.
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (25+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
engineguy is offline
post #10 of 20 (permalink) Old Feb 1st, 07, 10:32 AM
I run 1.75" X 3" Hedmans on a 10.3/1 233/236 .600/.610 lift hyd roller cammed ZZ454 motor. This motor hits harder at 3000 - 6000 RPM than any other motor combo I have ran. No question about it, the smaller tubes yield throttle response. Bought these when the car had a 396 motor and decided t give them a try with the bigger motor, glad I stayed smaller. With a 460CI motor, most likely would like a 2" x 3.5" for more power the other side of 6000. If it were me , a rec port 396 motor would get a full divided plenum intake and 1.75 primaries.
GRN69CHV is offline
post #11 of 20 (permalink) Old Feb 1st, 07, 7:56 PM
Tim
i used the hedman 1 3/4 x 3" in the painted version. i have raised port heads on mine. they fit ,but not good here a dent ,there a dent . also i ruined a pair of hedmans with 2 " primarys trying to make them fit. both sets were ( for my car). junk imo. my buddy used hooker comps with 2 ' x 3 1/2 " and they fit his 66 great ! did i say , yes i said great !
grovey is offline
post #12 of 20 (permalink) Old Feb 2nd, 07, 11:45 PM Thread Starter
Frank
Hello Everyone,
Thanks again for the good responses. I picked up a summit book @ work and I noticed that most if not all header companies smallest primary tube for a 396 is the 2 by 3 1/2. I even called summit and the tech guy confirmed it. I did call Comp cams and talked to the guy that helped me pick out the cam I am currently running. I explained my operating conditions and what exhaust I am going to run. The cam has a rpm range from 1600 - 6000. He recommended a 2 by 3 1/2. So now I guess it is going to be preference?
Thanks Again,
Frank
post #13 of 20 (permalink) Old Feb 3rd, 07, 10:24 AM
Hmmmm , lets see advice from lots of experienced BB folks here ..or advice from order taker at Summit and Comp !! What to do ??
,Tremec by Liberty
Engine
CDN SS is offline
post #14 of 20 (permalink) Old Feb 3rd, 07, 11:25 AM
Sheepster. BAH!
Ill never buy a "tuned " header again, too much of a pain as far as getting starter in, etc. If I could have bought a nontuned header in the same primary size I would have, they are much easier to install.
cuisinartvette is offline
post #15 of 20 (permalink) Old Feb 3rd, 07, 11:50 AM Thread Starter
Frank
CDN,
I just posted what I found looking for a 1 3/4" primary. After not finding them readily availible I contact summit since they have ALL of the different headers listings, some of which are NOT in the catalog. The tech guy @ Comp was very helpfull and knew his stuff when consulting him on a Cam for the car. The guy that did the cam swap for me races weekly in the summer and he also reccomended 2" primary. So I am not trying to say that you guys don't know your stuff. I am merely posting what I found.
Frank
Frank
This Thread is more than 3733 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Headers vs. Exhaust Manifolds Hoovestol Performance 0 Apr 13th, 06 5:44 PM
headers for Vortech heads different? rancherlee Engine 1 Apr 1st, 06 1:53 PM
Ceramic headers on new SBC BBaker Engine 3 Feb 22nd, 06 9:23 AM
Powdercoating Headers? RedSS454 Performance 6 Jan 29th, 06 4:43 PM
Exhaust Theory with Tuned Headers GRN69CHV Performance 0 Jan 7th, 06 11:34 PM
