Accel Motor Oil at Walmart. - Chevelle Tech
post #1 of 16 (permalink) Old Dec 26th, 06, 5:03 PM Thread Starter
Paul
Thumbs up Accel Motor Oil at Walmart.
I saw where one of our Walmart S/C's is selling Accel motor oil SF Grade for 1988 and older vehicles for $1.29/quart!!
I figure it has plenty of zinc in it!!
pdq67
pdq67 is offline
post #2 of 16 (permalink) Old Dec 26th, 06, 5:08 PM
Re: Accel Motor Oil at Walmart.
I'm going out to check on that Paul.
Aaron is offline
post #3 of 16 (permalink) Old Dec 26th, 06, 5:49 PM
Smile Re: Accel Motor Oil at Walmart.
I would not figure on it even though Accell states thier oil is for 1988 and down unless it says it's for non off road use like valvoline vr1 20-50 states.
This is because cars had cat converters way before 1988 and the ZDDP antiwear pkg in the older oils would clog them up too so why not before 1988,strange?
Also,Accell is not a large enough comp to be making oil on their own and its very likely that the Accell oil just a rebox of another larger oil companies std car motor oil made today without the ZDDP anti wear pkg.,most all of todays motor oil are void of the the ZDDP anti wear pkg.
It would be great if you were correct that Accell's oil had the ZDDP anti wear additives our flat tappet cams but intill they/Accell comfirms that you should not just assume its there and not use it IMHO.
Thats the reason why i took the time to contact Shell/Chevron/Valvoline to confirm which oils did & didnt have the ZDDP/Zinc/Moly in them and also to ask if the Reformulated for 2007 Shell & Chevron 15w-40 Diesel oils still had enough of the ZDDP anti wear pkg etc in it to still protect out cams/lifters which they confirmed as a yes . But i will be skeptical untill is see the refomulated #'s vs the pre-reformulated #'s for amont of anti wear chemicals in the oils.
So maybe you or someone els here can take the tourch and contact Accell on this one.
By the way what wt oil/s was offered by Accell when you saw it?
SCOTT
SWHEATON is offline
post #4 of 16 (permalink) Old Dec 26th, 06, 8:10 PM Thread Starter
Paul
I want to say either 10w40 or 20w40??
And it caught my eye b/c it's labeled SF so HAS to be of that formulation or they can get in BIG trouble b/c of the "Truth in Advertising" law.
And I figure that there aren't enough 1988 and older cars to even bother with ruining their cats b/c Ibet they are long ago ruined IF they are even still on the cars..
pdq67
pdq67 is offline
post #5 of 16 (permalink) Old Dec 26th, 06, 9:36 PM
The Driver
The Accel oil I saw at Wal Mart was straight 30 non-detergent SA rated for motor vehicles made prior to 1930 . It just might be better than what is offered now with all the good stuff that's been taken out.
Wooderson is offline
post #6 of 16 (permalink) Old Dec 26th, 06, 9:58 PM Thread Starter
Paul
Wrong bottle is all I gotta say!!
pdq67
pdq67 is offline
post #7 of 16 (permalink) Old Dec 27th, 06, 2:50 AM
The Driver
No kidding on the SA rating and 1930 reference for the 30W.
post #8 of 16 (permalink) Old Dec 27th, 06, 8:49 AM
SF does not mean that it HAS to have ZDDP. All it means is that they can get away with using cheaper basestocks that will oxidize and form sludge.
That is a low grade oil made with cheap basestock and likely a poor additive package. I'd never run it in my cars.
novadude is offline
post #9 of 16 (permalink) Old Dec 27th, 06, 9:40 AM Thread Starter
Paul
I will check deeper into this at work today b/c I think I can find a site that gives the meaning to those ratings in the little circle.
Later.
pdq67
pdq67 is offline
post #10 of 16 (permalink) Old Dec 27th, 06, 9:49 AM
Keith
Here in Ontario, cars and trucks over twenty years old don't need emissions tests. It wouldn't matter if the cat. converter does clog up. Our '87 S-10 truck still passed the tests last year and had been using all those old oils for all these years. The converter is original. I don't see that the additives were all that much of a problem.
Keith Tedford is offline
post #11 of 16 (permalink) Old Dec 27th, 06, 10:00 AM
Cheapest oil I would run would either be Pep Boys brand (Pro Line) or the Wal Mart Super Tech (or whatever its called..its in the blue bottle)
mr 4 speed is offline
post #12 of 16 (permalink) Old Dec 27th, 06, 11:05 PM Thread Starter
Paul
I know SF is obsolete, but I will bet a 6-pack of your favorite "Barley-Pop" to a donut hole that it has ALL sorts of zinc and calcium in it!!
Petrol Engines
Category Status Service
SM Current For all automotive engines presently in use. Introduced in the API service symbol in November 2004
SL Current For all automotive engines presently in use. Introduced in the API service symbol in 1998
SJ Still current but nearly obsolete For all automotive engines presently in use. Introduced in the API service symbol in 1996
SH Obsolete For model year 1996 and older engines.
SG Obsolete For model year 1993 and older engines.
SF Obsolete For model year 1988 and older engines.
SE Obsolete For model year 1979 and older engines.
SD Obsolete For model year 1971 and older engines.
SC Obsolete For model year 1967 and older engines.
SB Obsolete For older engines. Use this only when specifically recommended by the manufacturer.
SA Obsolete For much older engines with no performance requirement. Use this only when specifically recommended by the manufacturer.
pdq67
pdq67 is offline
post #13 of 16 (permalink) Old Dec 28th, 06, 3:39 AM
Derrick
i don't know if i'd touch the el-cheapo oil, but the Shell Rotella T diesel oil has plenty of zinc and what not in it, and costs like $6 for a 4 quart jug at Wal mart. it's the only non synthetic oil that doesn't turn to sludge in my turbocharged Regal, so it must be ok stuff.
does anyone remember the recycled oil Wal Mart used to sell back in the early 90's for like $.75 a quart? that stuff was nasty.
-Hank Hill
novaderrik is offline
post #14 of 16 (permalink) Old Jun 1st, 10, 10:49 AM
Rod
Originally Posted by pocvalfm
removed by admin
So, I'm guessing with 3 posts to your username and all in the same thread that you signed up here just to slam this company? You Googled the name of the oil and I guess this is the only place you could find on the internet with a discussion about that oil? You needed to vent.
Rmchevelle is online now
post #15 of 16 (permalink) Old Jun 1st, 10, 2:08 PM
Derrick
it might be an old thread, but at least it's an old pdq thread.
-Hank Hill
Accel shorty spark plugs??? Pro Street Garry Engine 12 Jun 11th, 06 3:40 AM
accel 8140 coil 5litre Electrical & Wiring 1 Mar 29th, 06 7:23 AM
Accel spark plugs jat70 Engine 11 Mar 15th, 06 9:36 PM
ACCEL Module gared69 Performance 3 Jan 29th, 05 8:37 PM
need help identifying accel efi parts dukejoh Performance 6 Nov 27th, 04 2:32 PM
