1969 chevelle 396 350 hp specs - Chevelle Tech
post #1 of 19 (permalink) Old Aug 21st, 06, 6:50 PM Thread Starter
Hello, I am new here, just came over from the camaro site. I have a 1969 396 350hp engine from a chevelle (code is JC) I was wondering what is the difference in the motor compared to a 325 hp motor. thanks
68impala is offline
post #2 of 19 (permalink) Old Aug 21st, 06, 7:21 PM
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
Talking Re: 1969 chevelle 396 350 hp specs
air cleaner decal extra 25 hp
The extra 25 hp
Carb is different I think and intake is different?
I have the same motor for my 69 vert, so I dont really know what else is different, someone else will chime in and tell us more.
I started with Nothing and still have All of Nothing!
Bad Brads 1969 Convertible SS
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
1badss396 is offline
post #3 of 19 (permalink) Old Aug 21st, 06, 7:36 PM
Bruce
Basically, the cam and valve springs were different, with minor differences in carburetor and distributor specifications. Intakes, heads, blocks, and pistons were the same. 350HP used same valve springs as 375HP.
Bruce
66 El Camino 396/325HP 4-Spd
My Build Thread: http://www.chevelles.com/forums/43-e...el-camino.html
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
90 IROC-Z convertible - For Sale
https://phoenix.craigslist.org/wvl/cto/5960984268.html
66 Corvair (Kelmark mid-engine conversion) (project, basic conversion complete, needs restoration)
66 Corvair (#2). My son's project. Small block, Powerglide, C5 differential and rear suspension
AZCamino is online now
post #4 of 19 (permalink) Old Aug 21st, 06, 8:01 PM
Air cleaner
325 hp was closed with snorkel, 350 hp was open element.
post #5 of 19 (permalink) Old Aug 21st, 06, 8:01 PM
Bruce
that is 100% correct
mr 4 speed is offline
post #6 of 19 (permalink) Old Aug 21st, 06, 9:42 PM Thread Starter
Thanks alot, I didn't think there was a difference. Is the crank cast or steel. This is a 2-bolt block. If anyone is near Youngstown Ohio and needs this engine I would consider selling it to some one who really needs it.
68impala is offline
post #7 of 19 (permalink) Old Aug 22nd, 06, 12:48 AM
It's probably cast.
'71 Malibu 402 big block/TH350 trans - Sold 2 Jan '08
How to tell if your car is a true SS or not:http://www.chevelles.com/shop/ss_ident.html
Junkyard Dawg is offline
post #8 of 19 (permalink) Old Aug 22nd, 06, 7:04 AM
von
Lifetime Founding Member
Von
There's the other difference. '69 350 hp has a forged crank vs a cast crank for the 325 hp.
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
von is online now
post #9 of 19 (permalink) Old Aug 22nd, 06, 8:35 AM
Smile Re: 1969 chevelle 396 350 hp specs
AZCAMINO & DEAN ARE 100% correct.
FYI,i know for sure the 69 & 70 396/325hp & 350hp motors both had nodular iron cranks from the factory,396/375's had steel cranks.
Its the earlier like 1966-67 396/350hp & 360hp motors that had steel cranks (along with the 396/375hp & 1965 Z16 396/375hp.) and different intakes along with holleys not q-jets as mentioned in above post/s .
The only noteable difference between the 396/325hp & 350hp motors in 69 was the 350hp had an open element air cleaner,larger secondary metering rods,a more agressive hyd cam & better valve springs for higher rpm of 350hp cam,and a different ign timing curve in the distributor but they both had 10:25:1 compression.
The stock 325hp hyd cam had approx 198/198 deg int dur @.05,.398/.398 lift,114 or 115 deg L/S angle which was an extreemly mild cam for a 396. The 350hp cam was called the high lift/high perf hyd cam which had 214/218 deg int dur @.05,.461/.480 lift,115 deg L/S angle which was considerably more cam then the 325hp had but was still a mild cam.
SCOTT
SWHEATON is offline
post #10 of 19 (permalink) Old Aug 22nd, 06, 1:45 PM
von
Von
All the references I have for '69's including the A.M.A. specs I received from Chevrolet as part of the restoration packet, show a forged crank for the 350 hp and cast nodular iron crank for the 325 hp. Before 1968, the 325 hp also had a forged crank.
[img]
von is online now
post #11 of 19 (permalink) Old Aug 22nd, 06, 2:22 PM
My info comes from GM too but as we all know it's not uncommon to find conflicting info from the general,it happens from time to time.
But i also know this 1st hand from buying my chevelle in 1978 from the original owner when it was new with the #'s matching motor/drivetrain still in the car.
When i pulled the virgin motor (396/350hp)for it's 1st rbld ever it had a nodular iorn crank in it from the factory as i verified from the casting id too even though i could tell just by looking at the casting itself.
The machinest commented on how that nodualr iron crank was a good street unit because it was stronger then a std cast crank but was a little more flexable then a steel crank that was more ridged & prone to cracking if/when flexed.
SCOTT
SWHEATON is offline
post #12 of 19 (permalink) Old Aug 22nd, 06, 9:34 PM Thread Starter
thanks again for all the info, I looked at the crank (while still in the motor) the only number I can see is 6223. Does that tell us anything?
68impala is offline
post #13 of 19 (permalink) Old Aug 22nd, 06, 9:55 PM
I believe that would be a forged crank. Funny, I have a 427 out of a 68 SS Impala in my car now.
69ssmike is offline
post #14 of 19 (permalink) Old Aug 22nd, 06, 11:23 PM
6223 is the most common forged crank. I have one that is a cross drilled 427 model but most are the non crossdrilled 396 type. Basically the only real difference between the motors is the cam. The valve springs are heavier and the jetting is different but is really just the cam.
Mike Feudo is offline
post #15 of 19 (permalink) Old Aug 23rd, 06, 11:18 AM
According to the AC Delco manuals i have the 396/325hp (7029201 q-jet std trans) & 350hp (7029215 q-jet std trans) motors use the same primary jets & rods (71's/45b rods),the only difference is the secondary metering rds,BC for 325hp & AX for 350hp.
The AX sec rods used in the 350hp motor have a much thinner tip and are richer then the BC rods used in the 325hp motor.
The 25 additional hp in the 350hp motor comes from a combination of a more aggressive cam profile & better valve springs for higher rpm potential,richer sec rods,open element air cleaner,and a different ign timing curve in the dist .
SCOTT
SWHEATON is offline
1969 COPO chevelle Ls6Convertible Copo & Dealer 40 Sep 15th, 10 10:44 AM
Starter bolt torque specs for '67 Chevelle Freebooter Engine 2 Jun 20th, 06 10:59 AM
1969 Chevelle SS Advice Agugliel72SS Restoration Corner 11 Feb 18th, 06 10:56 PM
I have a question about 1969 Chevelle 2dr ht 1969 Chevelle Dude Chevelle Tech 12 Jan 6th, 06 12:40 PM
convert 350 to 396 on 70 chevelle Ryan T Engine 16 Apr 26th, 05 8:07 PM
