slipped timing chain?? - Chevelle Tech
post #1 of 9 (permalink) Old Jun 13th, 06, 8:53 PM Thread Starter
How can you determine if a timing chain has slipped, without removing timing chain cover. This is a new 350 rebuild 3000 miles ago so I know chain is new and was properly installed then.
Struggling to get motor started after installing new stock HEI.
Did everything by the book, Constant 12V to coil, 10 degrees BTDC on compression stroke, rotor firing at #1 cylinder. lots of gas and strong spark.
any help would be appreciated. Just trying to rule out the chain slip before I focus on other possibilities.
thanks!!
archburycontrol is offline
post #2 of 9 (permalink) Old Jun 13th, 06, 9:18 PM
Greg
Re: slipped timing chain??
Please excuse me if this sounds ignorant (because I often am! ) Could you just pull the #1 plug rotate the piston up to top of the compression stroke and then pop the cap and see where the rotor is pointed?
If it's at the #1 plug wire terminal then the timing chain would still be ok, right?
Or, I might be missing something obvious because that seems too easy to work!
"the Special" SBC 355/TH350/12 bolt 3.90 posi
Best motor pass - 12.58 @ 107mph
Best nitrous pass (125shot) - 11.72 @ 115mph
http://www.cardomain.com/ride/2345518/1
66 Buick Special is offline
post #3 of 9 (permalink) Old Jun 13th, 06, 9:20 PM
I dont know what the experts will say, but I have been around engines for a long time, and I have yet to see a timing chain jump or slip. I dont believe it happens. Especially in your case, it's practically new. Did the engine run good before the dist. change? What else did you do. If you have spark and gas, it has to be a matter of timing. Just to check your theory, pull the left valve cover, bring it up to TDC on #1 compression stroke, and see that both valves are closed. Im willing to bet that if you re-do the distributor, check your wires (firing order) and all the basic stuff, it will fire up. Does it do anything at all? Pop a little or try to start? Did you mess with the valves at all, and are they adjusted properly?
The difference between intelligence and apathy?
I have no idea, and I couldnt care less.
Johns Ride
Johnny O is offline
post #4 of 9 (permalink) Old Jun 13th, 06, 9:46 PM
~Scott~
Send a message via AIM to ssal396
I have seen one, it was in my 69 Le Mans back in the 80's.. Although it was one of those old factory nylon timing gears & the teeth had all actually came off of the gear, all that was left were little nubs.. One day I went to jump on it and it just burped and died..
Then to make it even better, a couple of months after I struggled to replace the timing chain with the motor in the car, I found all those teeth IN THE FRIGGEN OIL PICK UP!! Yep, one day my oil pressure dropped to 0 at idle .. So then I got to have the fun of swapping out the oil pump with the motor in the car.. Oh, those were the days
.........Now, to get back to topic, I agree with the prevous posts.. It's more then likley the timing.. If this engine has yet to start since installing the timing chain, you might have installed it a tooth out or off of the compression stroke..
Just trying to throw out suggestions..
Scott Salerno - 1969 SS 396
TC # 2510
ACES # 6919
How cool is it that my initials are all over my car...
http://www.myspace.com/ssal396
My Car
2007 ACES Regional Show
ssal396 is offline
post #5 of 9 (permalink) Old Jun 13th, 06, 9:49 PM
Rich
If you adust the valves too tightly then both valves will be open and you won't be able to build any compression. Ask me how I know!! Has anyone else adjusted hydraulic-cammed valves on the engine stand only to have them keep the valves open once you get the lifters pumped up.....
1969 Chevelle Malibu
496 /th400/ford 9", 3.70 gears.
Best Time: TBD
Old Best:
408 big block / th350 / 4.11 powertrax 10 bolt
11.988@113.39 on BFG drag radials
1.782 60'
A.C.E.S. # 7037
http://www.chevelles.com/showroom/da...dium/MCC01.jpg http://www.chevelles.com/showroom/da...C_Show_015.jpg
69bu is offline
post #6 of 9 (permalink) Old Jun 14th, 06, 6:52 AM
Been doing this 32 years and have not seen a chain slip yet and was the cam degreed in or was the dots just lined up?????????
CNC BLOCKS N/E is offline
post #7 of 9 (permalink) Old Jun 14th, 06, 10:04 AM
did you get the ROTATION of the distributor correct? you can hook the wires up in the right order but if you are going the wrong way around the cap.... i have a 442 that i changed out the distributor on, and it didn't run. well, i had assumed it rotated just lilke a chevy, WRONG, it's goes the opposite direction.
GS
glennslanaker is offline
post #8 of 9 (permalink) Old Jun 14th, 06, 12:22 PM
Like someone in a previous post said pull the cap and the spark plug from #1 cylinder and make sure of all that.If you are going to HEI from points remember the #1 position on the cap isn't exactly the same for both.You probably have to turn the slotted drive around a little to get on #1.
BUDS1970 is offline
post #9 of 9 (permalink) Old Jun 14th, 06, 1:12 PM
Just pull the valve cover and crank it over to TDC and watch the valves on #1. This way you will be SURE to be setting the distributor to fire #1 and not #6.
Dave Bradley
d1_bradley is offline
Smoking and always rich SteveRoehll Troubleshooting 12 Apr 9th, 08 8:30 AM
Timing chain rubbing BigNeal Engine 2 Apr 4th, 06 6:01 PM
Still wont start!!!!!!!!!!!!! smitty454 Engine 37 Jan 7th, 06 3:44 AM
Timing chain slipped? rloyles Troubleshooting 4 Mar 3rd, 04 8:37 PM
Wrong timing chain? BigNeal Engine 1 Jun 3rd, 03 8:38 PM
