454 block ...14015445 - Chevelle Tech
post #1 of 2 (permalink) Old May 24th, 06, 1:41 AM Thread Starter
How does a 454 block.. ,casting# 14015445, ... generally rate concerning wall thickness and core shift? I'm new to BB's Thanks
brimac is offline
post #2 of 2 (permalink) Old May 24th, 06, 7:22 AM
Re: 454 block ...14015445
Pretty much average. Should go to .060 easily. any more than that and you should have it sonic checked. As for core shift, check to see how well centered the cam is in the bosses as the front and back of the block and how well centered the lifters are in their bosses. It's not always accurate, but if neither are even close to centered, chances are good that it has a good bit of core shift. You can sure ease your mind by having it sonic checked - then you'll know exactly how much cylinder wall you'll have after boring.
Gary Adrian
The correct spelling is
HILLIARY
Busted Knuckles is offline
This Thread is more than 4018 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Will 454 block be usable? MarkM Engine 7 Apr 17th, 06 1:07 PM
2 Bolt 454 Block londerville Engine 34 Mar 9th, 06 9:28 PM
Fitting on 454 CE block vferrizz Engine 6 Feb 3rd, 06 3:34 AM
Building a New 454 - Advice anyone? Danspeed1 Engine 9 Oct 10th, 05 8:58 PM
454 block # mdd71 Tag Team 1 Apr 30th, 05 9:10 PM
