Just added Hydroboost - Incredible - Chevelle Tech
 4Likes
post #1 of 37 (permalink) Old Mar 5th, 17, 12:04 AM Thread Starter
Thumbs up Just added Hydroboost - Incredible
Two weeks ago, as I bled brakes after 2 year frame off resto, and still felt crappy brakes, I decided to go for hydroboost kit.....spending all that money to make a car go fast and look good, felt it important to be able to stop. Just road tested it today. Talk about incredible pedal response and stopping......one of the best Chevelle investments ever for me.....went with CPP unit with Chrome M/C and stainless lines. Was able to keep my Wilwood discs, rear drums, same brake lines, and prop valve. If you are contemplating HB, do it.... you won't believe how fantastic. was very easy install and looks good to me too. before and after pics below. anyone interested in slightly used Wilwood M/C, booster, and vacuum canister? can't get that one pic to upload correctly...sorry
ID:	425362   Click image for larger version
OLDED, 66 Bu and Schwany like this.
Skier_Bob is offline
post #2 of 37 (permalink) Old Mar 5th, 17, 11:09 AM
Re: Just added Hyrdoboost - Incredible
try the free classifieds for selling your stuff.
post #3 of 37 (permalink) Old Mar 5th, 17, 12:43 PM
agreed! Hb is the best upgrade I have done to mine so far, with the exception of needing to upgrade my fillings. These things under emergency conditions will bring the Beast down and quick! Like an anchor tossed out behind the car!
Ahh the fillings.. maybe I will wait till I have dentures and see the teeth mounted on the inside of the windshield!
I'm the Haught guy...
haughty is the nic, not the attitude....
2004 GMC Pickemup-
1972 Malibu. Paint jail......
2015 Hyundai Santa Fe GLS Ultimate
2001 BMW K1200 LT (Sally Ride)
the preceding comments and comparisons made either to real or fictitious characters are wholly made up with insult to no one. If this does, my apologies as it is just icing on the cake...
haughty is online now
post #4 of 37 (permalink) Old Mar 6th, 17, 12:15 AM
Mark
Did you get the back brakes adjusted properly? Did you just open the valve on the port until they locked up? The CPP instructions aren't too clear on the adjustment procedure.
'69 Chevelle SS (Almost on the road, and it runs again, but in the body shop for a while.)
ZZ502 Short block
Comp Custom Magnum HR 306/303 Adv dur 246/248@ .050 .680/.647-112LSA-108 ICL (Crap!...ate the cam's distributor gear!)
NEW CAM: Bullet HR ADV Dur 295/297 238/242 @ .050 .680/.650-110 LSA-108 ICL Morel lifters
Holley Avenger MPFI
612HP/594TQ (Dyno numbers with the Comp Magnum Cam)
T-56 Magnum trans with McLeod RST
MarkP is offline
post #5 of 37 (permalink) Old Mar 6th, 17, 1:00 AM
Rod
Cool, I have the same set up. I didn't have too good of luck with some of CPP's other stuff so I was a little worried about the hydro boost. This makes me feel a lot better.
1966 Malibu, 540 BBC FAST XFI EFI, 4L80E Trans, 2800 Stall, Quick Performance 59" 9" Ford Rear End w/3.50 gear
66 Bu is offline
post #6 of 37 (permalink) Old Mar 6th, 17, 4:44 AM
Rod, how does that 59" rear axle work in your 66? That's like an inch narrower that the stock axle, right?
post #7 of 37 (permalink) Old Mar 6th, 17, 6:12 AM
Pat
I had one of the Hydratech units on my 72 Camaro and agree they provide amazing brakes. It is certainly on my "to do"list for my 70. Great stopping power and also think they look great under the hood.
Pats70ss is offline
post #8 of 37 (permalink) Old Mar 6th, 17, 4:37 PM
Larry
Hi Tom, I ordered a 58" moser 12 bolt for my '66 , worked well with 15x8 wheels with 4.5"bs , it's a 66 GTO running a 66 Chevelle chassis,
Cowfarmer is offline
post #9 of 37 (permalink) Old Mar 6th, 17, 7:17 PM
Larry, are the tires close to the frame or inner fenderwell?
post #10 of 37 (permalink) Old Mar 6th, 17, 9:48 PM
Max
Love my Hydroboost. Definitely recommend the 1 1/8" bore master cylinders over the 1" and I've tried both. Nice and firm pedal.
1969 Chevelle SS (street car)
496BBC - 10.5:1 Pump Gas
LGT700
665HP/658TQ
| Jensen's Engine Tech | SilverSport Transmissions |
max69chevelle is offline
post #11 of 37 (permalink) Old Mar 6th, 17, 10:08 PM
Rod
It's really nice, I couldn't get the wheels in an off set to work with the stock width, and I was going to upgrade the rearend anyway, so, I just had them narrow my new 9" to 59" when I bought it. It didn't cost anymore than a 60" one so it worked out well. Got it from Quick Performance in Iowa, super guy and super to work with. I also got my drive shaft from him as well. The best part about it is that he is significantly cheaper than the usual suspects.
My wheels are Ridler 695's and originally thought that I'd buy them to mock up the car with but once here I really liked them. Kind of reminds you of the 80's with the Cragers yet a bit of a modern look. I like the soft lip and the fact that they chrome the wheel all of the way out the back, unlike others that usually stop once you get to the hub, at least the 'good' chrome. And, I bought 4 of them for the less than the price of one of those really fancy, light weight, forged offerings. I may not be as cool but I'm happy...
66 Bu is offline
post #12 of 37 (permalink) Old Mar 6th, 17, 10:48 PM
Larry
With a MT et street radial 275/60 the tyre is about 1/2" away from frame, maybe a little more haven't looked in a while ,
post #13 of 37 (permalink) Old Mar 7th, 17, 11:27 PM Thread Starter
Mark -----Never saw instructions regarding setting the back brakes.....HS! will have to check it out....thanks for mentioning it
post #14 of 37 (permalink) Old Mar 9th, 17, 12:24 AM
Mark
I have a different master cylinder, so yours may not be adjustable. Mine doesn't use a proportioning valve because it is built into the master cylinder. You can see it in my "Garage" in the "Under the Hood" section.
ZZ502 Short block
Holley Avenger MPFI
MarkP is offline
post #15 of 37 (permalink) Old Mar 10th, 17, 2:45 PM Thread Starter
Roger that Mark. Thanks. That Prop valve is a pain..especially it being on the frame. Wish I had known you can move it close to the M/C or eliminate it entirely before I redid my brakes. will next time!!
