anyone using these calipers?? - Chevelle Tech
 5Likes
post #1 of 31 (permalink) Old Mar 4th, 17, 12:01 PM Thread Starter
"Aussie"
Question anyone using these calipers??
My brother, (a Chevelle guy) has a friend who replaced the 307 in his '71 Malibu with a 454. Among other things, he replaced the single piston GM front disc brakes with these Wilwood calipers. He wanted keep his stock Rallye wheels and thus rotors, He claims these new Wilwoods have dramatically improved his braking over the GM single piston OEM's. It sound like an interesting upgrade for my '68 GTO which was converted to the single piston calipers discs years ago.
Has anyone used these calipers on their A-body and if so, what did you find/think about them? Thanks!
https://www.summitracing.com/search?...%20140-11290-R
"No replacement for displacement!"
BigBlockLover496 is offline
post #2 of 31 (permalink) Old Mar 4th, 17, 12:28 PM
Rich
Re: anyone using these calipers??
You don't have the correct link.
HandOverFist is offline
post #3 of 31 (permalink) Old Mar 4th, 17, 3:33 PM
Levon
This?
https://www.summitracing.com/int/par...6-rd/overview/
Levon Hovagimian
Team Chevelle #279
70 Chevelle SS 454 LS5 4 speed.
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
LevonH is offline
post #4 of 31 (permalink) Old Mar 4th, 17, 3:54 PM
gary
You need to do the math & find the square inches of each caliper. More = more braking at the same pedal pressure.
1967 chevelle malibu is online now
post #5 of 31 (permalink) Old Mar 5th, 17, 12:12 AM
I have them on my 71....were ok with vacuum, now with newly added hyrdoboost they are king!
Skier_Bob is offline
post #6 of 31 (permalink) Old Mar 5th, 17, 7:22 AM
Just put a set on a 66 on Saturday great looking. Will see how it stops on sunday need to finish the master cyld.
1967 ElCamino
454 HO GMPP
powder coated frame
Marina blue
MCC 836
bluefishgary is offline
post #7 of 31 (permalink) Old Mar 5th, 17, 11:41 AM Thread Starter
"Aussie"
Originally Posted by LevonH View Post
YES! Typos can kill a person
post #8 of 31 (permalink) Old Mar 5th, 17, 11:43 AM Thread Starter
"Aussie"
I assume you mean the sq in of each caliper piston surface? Or something else? Thanks!
post #9 of 31 (permalink) Old Mar 6th, 17, 4:37 AM
those calipers are listed as having 2 x 2" pistons. 2 x 2 x .7854 = 3.1416 x 2 pistons = 6.28 sq in of piston.
That's actually pretty close to the right size which is around 7 sq in.
incidentally, .7854 is equal to Pi/4, which is why the math works out like that.
Too bad they didn't produce those calipers with 2.125 piston, would have been very close to exact.
post #10 of 31 (permalink) Old Mar 6th, 17, 10:18 AM
gary
Yes it is the square inches of all pistons on the same side. Adding pistons to the oposite side does not add braking force.
post #11 of 31 (permalink) Old Mar 6th, 17, 10:58 AM Thread Starter
"Aussie"
Thanks! That makes for objective comparisons. Out of curiosity, does anyone know the piston area of the GM single piston on thhe "single piston" caliper? Appreciate it!
post #12 of 31 (permalink) Old Mar 6th, 17, 11:06 AM
Installed them on my Nova and noticed a big difference in stopping distance. The piston surface area is a little smaller but spread more evenly across the pad. Don't know if that was the difference but the car stopped better than with the stock iron caliper.
63 Nova wagon
Philip is online now
post #13 of 31 (permalink) Old Mar 6th, 17, 11:16 AM
Originally Posted by BigBlockLover496 View Post
Thanks! That makes for objective comparisons. Out of curiosity, does anyone know the piston area of the GM single piston on the "single piston" caliper? Appreciate it!
2.934" is the OD of the stock piston. If my calculations are correct the area is 6.75".
63 Nova wagon
post #14 of 31 (permalink) Old Mar 6th, 17, 11:57 AM
Levon
Tom, can/will you elaborate on the sizing? I've always been curious about the math and sizing. Your wisdom is always appreciated.
Levon Hovagimian
Team Chevelle #279
Priddis, Ab. Canada
My Showroom
LevonH is offline
post #15 of 31 (permalink) Old Mar 6th, 17, 1:17 PM
Rob
Big difference between the 2" piston version and the ones with nearly 3" size which are much better.
My build thread> http://www.chevelles.com/forums/56-pro-touring/613546-65-chevelle-2dr-post-car-build-thread-aka-chevelle-hell.html
65chevelle300post is offline
