64 Steering column diameter - Chevelle Tech
post #1 of 1 (permalink) Old Jun 15th, 05, 8:46 AM Thread Starter
Send a message via AIM to Ed_64SS
I've read the tech reference where it mentions the steering column diameter on a 64 being 13/16, but when I measured mine, it looked like it was 11/16. Is that possible? Could my measurements be off by an 1/8? I didn't have a caliper handy and used an adjustable wrench. Took the measurements quite a few times. Above and below the joint. Same size. It sure is skinny.
I'm thinking, crude measuring tools introduce too much error. Just want to make sure before I replace my rag joint.
64 Malibu SS
Ed_64SS is offline
This Thread is more than 4391 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
loose steering wheel six8malli Brakes, Suspension & Steering 5 Dec 7th, 04 10:34 AM
Correct steering column ?? Texas70 Restoration Corner 3 Jan 29th, 04 3:31 PM
1968 Steering Column Survey JIML82 Restoration Corner 3 Sep 23rd, 03 11:25 PM
Floor shift steering column Texas70 Restoration Corner 2 Aug 21st, 02 3:00 PM
1966 steering column clarktrip3 2002 7 Mar 31st, 02 9:12 PM
