Anyone had this happen??? - Chevelle Tech
post #1 of 6 (permalink) Old Jun 13th, 05, 12:40 PM Thread Starter
Over the winter I did a complete Polygraphite front end rebuild. I also put new 1 inch lowering springs on the front with stack height in the rear and new KYB gas shocks. Well anyway, my front upper control arm on the passanger side lost the nut in the rear bushing and the bushing came out!!! I did not press the bushings in, I had a local shop do it. Here are my questions. 1 - is this common? 2 - should the shop be willing to press the new bushings in at no cost? 3 - Am I just an idiot for not tightening the thing to ensure it was tight? The other bolt in the control arm bushing is fine as is the driver side control arm bushing bolts.
oregonchevelle+ is offline
post #2 of 6 (permalink) Old Jun 13th, 05, 1:37 PM
heathensumbitch
Send a message via AIM to Cecil Send a message via Yahoo to Cecil
Re: Anyone had this happen???
Yes, it happens regularly. Keep a 9/16 wrench handy and give 'em a good tug whenever you get a chance. Don't know about the shop, since it's not really their fault...
"Let not the sands of time get in your lunch..." Monty Python
Cecil is offline
post #3 of 6 (permalink) Old Jun 13th, 05, 2:12 PM
Mark
FYI, the compression lock nuts are only good for one compression. If that's the type you are using you might want to consider nylock or similar as a replacement, and/or use loctite on the threads for good measure.
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Xtreme70SS396 is offline
post #4 of 6 (permalink) Old Jun 13th, 05, 3:24 PM Thread Starter
No nuts just the bolt threaded in there. I will be checking for now on.
post #5 of 6 (permalink) Old Jun 13th, 05, 4:01 PM
Happens all the time
Mine were loose before cb05 locktight them.
TC#355
aces member #03260
69SS396
69 convertible
68 convertible
72 Olds 442 convertible
(JBROWN)
http://www.chevelles.com/forums/imag...4&type=profile
69SSRat is offline
post #6 of 6 (permalink) Old Jun 13th, 05, 4:34 PM
Mark
Sorry, I converted mine when I went to the offset shaft to nuts. Sounds like loctite is your only bet + regular checking.
Mark
1970 SS396
634 HP @ 6000rpm
ProSystems SV1
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
What would happen if I ran 91 octane? OUChevelleSS Performance 7 Apr 6th, 05 6:56 PM
What would happen with no throttle return spring? OUChevelleSS Performance 3 Dec 8th, 04 4:14 PM
engine problems. What happen???? german Engine 4 Aug 13th, 03 12:46 AM
how could this happen chevelle 71 Engine 1 Jan 20th, 03 2:43 PM
