Since I got no info on my brake upgrade question, I'll attempt to break it down into segments.
Using the frame mounted 67 distribution block, would there be an issue in installing a Willwood type adjustable pressure valve in the rear line from the master to the distribution block? The valve pictured below.
To recap, I'm running C5 calipers in the front snd the stock drum brakes in the rear.
I've never taken apart or refurbished a distribution block before. Is this something that's easily done? Mine's been disconnected for a while. Are there any specialty seals or o rings inside it?
Thanks in advance!
Thanks in advance!
