70 Power Steering hose routing - Chevelle Tech
post #1 of 3 (permalink) Old Oct 23rd, 12, 8:33 PM Thread Starter
Can someone tell me which power steering hose goes in the factory hook that is bolted on the power steering gear box? Should it be the high pressure hose or the low pressure hose? If someone has a picture of the hose routing that would be helpful.
mch6970ss is offline
post #2 of 3 (permalink) Old Oct 24th, 12, 12:23 PM
Re: 70 Power Steering hose routing
It is the Low Press. or return hose that goes into the hose cradle, Also do not forget the " U " shaped spring steel clip that holds the hoses together just ahead of the hose cradle. Also the org. hoses have a hard foam cover to prevent chafing.
Robinls5 is offline
post #3 of 3 (permalink) Old Oct 24th, 12, 6:34 PM Thread Starter
Thanks Bob. I suspected it was the return hose but just wanted to be sure. I'll see about getting the spring clip to finish the job.
