69 chevelle steering seems loose - Chevelle Tech
post #1 of 4 (permalink) Old Mar 18th, 12, 9:33 PM Thread Starter
Maciek
In my 69 chevelle, the steering seems very loose, about 1/4 turn on the steering wheel of play, and no action to the wheels. Which parts should I look at to improve this and help tighten up the steering?
rudy69 is offline
post #2 of 4 (permalink) Old Mar 18th, 12, 9:48 PM
Re: 69 chevelle steering seems loose
Im going to say worn gear box. And if you replace it i would do the Jeep Grand Cherokee box.
1968 Chevelle SS clone 03 LQ4 6.0l, D1SC Procharger 14lbs,AIS Methanol Injection,TFS/TEA 220 heads, BTR Cam 231/242 .617/.595 111, RKT Built t56, Fully built 12 bolt with 3.73 gear. 658rwhp 575rwtq
http://ls1tech.com/forums/conversion...-ls-knife.html
GsxrDave is offline
post #3 of 4 (permalink) Old Mar 19th, 12, 12:01 AM
Bruce
The first part I'd check would be the rag joint. I've seen them with three of the four connectors broken -- that results in a great deal of play. Have someone turn the wheel while you watch the joint.
The second thing I'd check is the steering gear box. Crawl under the car so you can watch both the steering shaft and the Pitman Arm. If the shaft turns a lot and the Pitman Arm does not then I'd suspect the box needs to be rebuilt (if you're into numbers there is a Date Code on the box access plate) or replaced.
"CQQL" my Nickey Chicago 1969 Chevelle COPO Tribute: http://s1012.beta.photobucket.com/us...88981229984076
Our You Tube Vids: http://www.youtube.com/user/NickeyCh...ow=grid&view=0
NickeyChevelle is offline
post #4 of 4 (permalink) Old Mar 19th, 12, 3:06 AM
ANYTHING loose in the front suspension/steering will create additional play in the steering wheel.
Idler arm, tie rod ends, ball joints, control arm bushings...the list goes on.
Schurkey is offline
