65 disc brake conversion - Chevelle Tech
post #1 of 4 (permalink) Old Apr 4th, 11, 12:41 AM Thread Starter
I am considering converting to front discs. I see rotors that bolt to existing spindles that I assume would be much easier to install than replacing the spindles. I see they are 11" rather than 13" and move the wheels out 7/16" I have 14" wheels. Any one have these installed what are your experiences. Is braking much improved and is the 7/16" off set a problem?
grey_ghost is offline
post #2 of 4 (permalink) Old Apr 4th, 11, 12:57 AM
Sean
Re: 65 disc brake conversion
it's not that hard to swap spindles. do some searches here, there is a ton of info about disc brake swaps. depends on your budget, mechanical ability, and desired end result. lots of different ways to go.
Sean
'65SS, 385ci, AFR 195's, Comp XR 288HR, Forged bottom end, TKO600, 3.73/12 Bolt
Now in our new home in Tucson AZ
http://spotted.stripes.com/galleries....php?id=337573
"Aint no fun 'till somethin gets broke!"
troposcuba is offline
post #3 of 4 (permalink) Old Apr 4th, 11, 6:14 AM
Thomas
With 14" wheels you may encounter a problem with most brake kits. In some cases the 7/16 offset can cause the tire to rub the wheel well lip at the top.
http://www.carolinachevelle.com
Carolina Chevelle Association
TC # 688
ACES 2759
PeachState Chevelles
http://www.chevelles.com/forums/albu...pictureid=6381
66 malibu wagon, 327, AC, pw.
67 chevelle 300 deluxe post, LT1-4L60E, 3:36-10 bolt posi,AC,tilt,pw,pl, Autometer gauges,custom dash
"I think we have more machinery of government than is necessary,
too many parasites living on the labor of the industrious."
--Thomas Jefferson, letter to William Ludlow, 1824
elcamino66 is offline
post #4 of 4 (permalink) Old Apr 4th, 11, 11:29 AM
I recently installed Power Disc brakes from Bear on the front of My 65 Chevelle. Big improvement over drums. Best upgrade I did. The kit I got fit inside my 14 rims. I dont like the big wheels. The brakes I got didnt have the rotors. I got 1969 or 1970 Chevelle rotors from the local Auto store. Cant remember exact year. Everthing worked out. They fit on the spindles. Other companys do make kits that fit inside 14 inch Wheels. jemoore24
jemoore24 is offline
