What size rear suspension bolts? - Chevelle Tech
post #1 of 4 (permalink) Old Mar 25th, 10, 4:54 PM Thread Starter
alfred
Does anyone know where I can get new bolts for the rear suspension?
I like the design of the oem with flat shoulder the fits snug in the sleeve of the bushing and the tapered tip the makes pushing the bolt thru easy. I want to get the full set of 8 bolts plus the 4 bolts for the Rear sway bar.
Should I just order these new or does anyone know the sizes so I can get them at the hardware store?\
70 Monte Carlo-461,th400 3500 stall 3.73gear-Lunati cam'd
72 El camino-454, th400 stock
FerrariTruck is offline
post #2 of 4 (permalink) Old Mar 25th, 10, 6:19 PM
Re: What size rear suspension bolts?
http://www.amkproducts.com/
Pete 67 is offline
post #3 of 4 (permalink) Old Mar 25th, 10, 6:47 PM
Control arm bolts are 1/2" x 4" grade8.
'69 SS396 -Build Thread A mishmash of American made suspension components and Australian brakes. L33 obtained, swap in planning phase.
Originally Posted by Busted Knuckles View Post
Being politically correct is kinda like trying to pick up a turd by the clean end.
GenPac is offline
post #4 of 4 (permalink) Old Mar 25th, 10, 7:06 PM
Hank
1/2" x 4" grade 8 works fine. Put a little anti-seize grease on them so they don't rust and seize up in the bushing sleeves. Original were grade 5 I believe and do have the shoulder near the head. Rest of the shaft is less than 1/2" so it won't seize up in bushing with rust.
Hank
My Chevelle
Finally is offline
This Thread is more than 2589 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
