Moog front coil spring install: white mark up or down? - Chevelle Tech
post #1 of 13 (permalink) Old Nov 15th, 09, 6:11 PM Thread Starter
Dwight
The Moog front coil springs I have for my 69 have a white mark on one end. Yes, I misplaced the installation notice sometime ago. I looked at both ends and could not really determine a flat portion. Any help? Does the white spot go up or down?
TIA,
Dwight
'69 Chevelle SS restoration in progress
http://s1130.photobucket.com/home/67vetteguy
67 vette guy is offline
post #2 of 13 (permalink) Old Nov 15th, 09, 7:03 PM
Re: Moog front coil spring install: white mark up or down?
Not sure on the white marks. Upper part of coil is noticeably flatter. End that sits in the control arm will have the pigtail slighty down. Just curious what spring did you get. I had 5390's in there, had to cut 1/2 coil for ride height, spring was still a little too stiff for my liking. I just installed 5372's. listed as std spring for 70-72 w/o AC. Very happy with these. Ride height is good, ride is nice.
GRN69CHV is offline
post #3 of 13 (permalink) Old Nov 15th, 09, 7:17 PM
The right choice Moog #5372 we have been using it for years in all Chevelles.Ride /height/ the right way to go~~~~ finally Bob Rizzi
Rizzi427 is offline
post #4 of 13 (permalink) Old Nov 15th, 09, 7:32 PM
LS7
Originally Posted by 67 vette guy View Post
The Moog front coil springs I have for my 69 have a white mark on one end. Does the white spot go up or down?
I want to say the top (UP) but not %100 sure, IIRC the instructions may be on the box. I can check a box I have in the garage attic if necessary.
LS7 is offline
post #5 of 13 (permalink) Old Nov 15th, 09, 7:45 PM
John, 100% right "white" goes up ^ MOOG/ Bob RIZZI
Rizzi427 is offline
post #6 of 13 (permalink) Old Nov 15th, 09, 8:01 PM
LS7
Thanks for the confirmation Bob. It has been a couple of years since I replaced a pair of front coils, and the old memory isn't what it used to be.
LS7 is offline
post #7 of 13 (permalink) Old Nov 15th, 09, 8:12 PM
John,no problem I hit 60 this year and have had this Chevelle "Thing" since 1965.When I work on these cars I go down as smooth as oil but I can't get back up !!!!
Rizzi427 is offline
post #8 of 13 (permalink) Old Nov 15th, 09, 8:29 PM Thread Starter
Dwight
On my Ground Up bill... it just lists 69 big block. If it matters, my car has factory air. I remember see some numbers stamped on one end. The chassis is across town. I'll check ont the stamping info. Thanks to all...
Dwight
post #9 of 13 (permalink) Old Nov 17th, 09, 11:34 AM
Speaking of coils. I also bought a set of Moog coils from Groundup. IS there a trick to get them in? I am using a spring compressor, but I just can't get them compressed enough to get them in. I'm working with a bare frame, so there's no weight on the frame to use a jack to install them. Any ideas? I spent about 4 hours last night with no luck. And don't suggest bagging it with air bags!
Chevelle4evr is offline
post #10 of 13 (permalink) Old Nov 17th, 09, 1:14 PM
This worked for me with my bare frame...
http://216.178.81.108/forums/showthr...spring+install
david
6t7gto is offline
post #11 of 13 (permalink) Old Nov 17th, 09, 4:29 PM
I thought about that, but the rental I have from Advance Auto won't work in my favor that way. The threaded part is too wide for the shock tower hole, just by a little bit. Would it be wise to widen the shock tower hole in order to slide in the thread? Either that, or do the reverse, mount it on the control arm end and rachet down. The latter seems very dangerous and scary. I'm almost sorry I took them off. Taking them off was easy compared to this!
Thanks in advance!
~Will
post #12 of 13 (permalink) Old Nov 17th, 09, 5:32 PM
Rocky Hill
Take a 4 x 4 thats long enough to go from your frame to the ceiling in your garage, with a smaller piece of 4 x 4 that will span across a couple of ceiling joists for support. This will spread the pressure across a couple of joists.
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
Mid America Chevelle Club
Queen City Chevelle Club
Heartland Chevelle Club
My Showroom
rocks66ss is offline
post #13 of 13 (permalink) Old Nov 17th, 09, 8:53 PM
Just installed some and the instructions said white mark up
mwiggett is offline
