Alignment shims - Chevelle Tech
post #1 of 1 (permalink) Old Oct 30th, 09, 5:58 PM Thread Starter
Alignment shims
When replacing the stock upper a-arm shafts with the offset shafts, do you add back all the shims that you previously removed or do you add/delete shims because of the offset? I know I'll have to have the front end aligned so I need whatever is necessary to get to the alignment shop. Is there some rule of thumb used? Thanks.
Tino #28 Gold
72 Malibu 454 TH400, 12 bolt 3.08
05 Silverado Z71 5.3 L33
83 Grand Prix LJ 305
Tino is offline
This Thread is more than 2767 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
