Any one ever try these bracket for front disc swap? - Chevelle Tech
post #1 of 5 (permalink) Old Feb 18th, 04, 5:54 PM Thread Starter
Todd
Send a message via AIM to RingMaster4x4
Post
I found these on Ebay. I just wanted to know if anyone ever tring them OR can someone tell me why I should not try it?
www.fquick.com/Ringmaster4x4
Go Big or Go Home!
(Mud Frog) 1972 K5,427 tall deck,SM465/NP205 ,18" Over Stock,44" GH Tires, D60/14BFF,on a custom twin framerail tube chassis. (blew motor)
(RICE KILLA) 1972 Chevelle 325ci TR224 On 112/ 2002 carmaro T56 6-Speed, 4 wheel power disc, 12 bolt w/ eaton & 3.55,
RingMaster4x4 is offline
post #2 of 5 (permalink) Old Feb 18th, 04, 5:55 PM Thread Starter
Todd
Post
I forgot to add the link. Brackets
Go Big or Go Home!
post #3 of 5 (permalink) Old Feb 18th, 04, 6:04 PM
Derrick
Post
they don't look too bad- maybe a bit bulky with a lot of unnecessary metal on the bottom side, but too much is better than not enough, i guess. i just wonder why they use the metric calipers? they are small, but cheap to get. the price doesn't seem too bad- you might have a couple hundred into the swap after you buy the brackets, rotor, calipers, hoses, and a master cylinder, which isn't too bad, i guess.
-Hank Hill
novaderrik is offline
post #4 of 5 (permalink) Old Feb 18th, 04, 6:15 PM
Dennis
Post
Whats the point of only going to a 10.5" rotor? If your going to go through the trouble might as well step up to 12 or 13", not that much more work.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."
Thomas Jefferson
sinned is offline
post #5 of 5 (permalink) Old Feb 18th, 04, 6:49 PM
Post
Like the idea,
Disc brake swap cheap!
Check the link to their home page. They have a 12" kit that uses the of offset shafts and/or Global West upper control arms.
One on ebay http://cgi.ebay.com/ebaymotors/ws/eB...tem=2460136360
or their home page http://www.scarebird.com/4436.html
Thoughs anyone?
John C.
Sapulpa
OKLAHOMA!
1965 2dr wagon project
johnyac is offline
