Steering Pump GC - Chevelle Tech
post #1 of 2 (permalink) Old Apr 26th, 09, 4:53 PM Thread Starter
Send a message via AIM to Tomb7us
Steering Pump GC
Im going to do the GC swap in my chevelle, and i would like to change the power steering pump to the metric fittings. Will any mid 80's GM truck pump have the correct fittings? Or do i need a few specific vehicles?
I can get a mid 80s chevy pick up truck pump cheap, but the vehicle it came from is unknown.
1969 Chevelle 454
Tomb7us is offline
post #2 of 2 (permalink) Old Apr 26th, 09, 10:47 PM
Re: Steering Pump GC
I used a fitting/spring out of a '85 Olds Cutlass, not sure about the truck fitting. One uses a '80 Camaro pressure hose for this swap so I imagine most of the GM 80's cars use the metric female end and the SAE male fitting for the pump.
The trucks I believe used the same pumps, but not 100% sure.
The fittings are cheap, hit up your local wrecking yards and pull one out.
My 70-->
http://i50.photobucket.com/albums/f3...3/IMG_0770.jpg
'71 Chevy C10 short fleet LQ4/700R4
'61 Lincoln Continental
'79 Hurst Olds 6.0/4L80E
Distant thunder, cold as stone, a big block Chevelle screams down from it's throne, one by one each car succumbs, something wicked this way comes.
THORSS70 is offline
This Thread is more than 2949 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
