OE Small Diameter Booster to replace 11" one? - Chevelle Tech
post #1 of 10 (permalink) Old Apr 20th, 09, 10:20 PM Thread Starter
I have a 66 chevelle that has the stock style 11" 68-72 brake booster. I need to replace it with a smaller diameter one to clear my BBC. Does anyone know of a smaller diameter booster that was original equipment on something that can replace my 11" one without losing the ability of the 11" one?
Strokd66 is offline
post #2 of 10 (permalink) Old Apr 21st, 09, 2:20 PM
Re: OE Small Diameter Booster to replace 11" one?
Look at the Chevy Monzas from the 70's - a nice smaller dia. and good pedal feel. Should bolt up - just be sure to check for the plunger rod length to be the same.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #3 of 10 (permalink) Old Apr 21st, 09, 3:38 PM Thread Starter
by going with that single diaphragm 9" booster wont I be downgrading?
Strokd66 is offline
post #4 of 10 (permalink) Old Apr 21st, 09, 3:48 PM
clif
I went from a 11" booster to a 9" booster on my BB "70 Chevelle.....no difference in performance
cwilks is offline
post #5 of 10 (permalink) Old Apr 21st, 09, 4:13 PM
What I did... went to the local Pick-n-Pull wrecking yard and found a '79 El Camino with a 8 or 9 inch dual diaphragm booster. Yanked it out. Whacked the mounting brackets off of my old 11" monster. Modified the holes in the brackets slightly and bolted them onto the '79 booster. Cut off the ends of both booster pushrods, added some threads and a coupling nut.
Bolted it in and works just as well as the old one with much more room around the BBC and tall valve covers.
1968 El Camino, 402 with TKO
vrooom3440 is offline
post #6 of 10 (permalink) Old Apr 21st, 09, 7:36 PM
T
I haven't tried it, but I would think so. Single diaphragm 9" booster has less area than the 11" job, so the max available force would be less. They can tune the valving to change the RATE of boost (or so I'm told) so you might be able to get the 9" to feel the same up to a point, then you reach max boost on the 9" job (booster runout).
I'd think a 9" dual diaphragm would be a better choice (same area as the 11")
According to RockAuto, you can find these on the following vehicles (among others)
Code:
BUICK    CENTURY    (1980 - 1981)
BUICK    CENTURY CUSTOM    1979
BUICK    CENTURY ESTATE WAGON    (1980 - 1981)
BUICK    CENTURY LIMITED    (1979 - 1981)
BUICK    CENTURY SPECIAL    1979
BUICK    CENTURY SPORT    (1979 - 1980)
BUICK    REGAL    (1979 - 1981)
BUICK    REGAL LIMITED    (1979 - 1981)
BUICK    REGAL SPORT    (1979 - 1981)
CHEVROLET    EL CAMINO    (1979 - 1981)
CHEVROLET    MALIBU    (1979 - 1981)
CHEVROLET    MALIBU CLASSIC    (1979 - 1981)
CHEVROLET    MONTE CARLO    (1979 - 1981)
GMC    CABALLERO    (1979 - 1981)
OLDSMOBILE    CUTLASS    1980
OLDSMOBILE    CUTLASS BROUGHAM    (1980 - 1981)
OLDSMOBILE    CUTLASS CALAIS    (1979 - 1981)
OLDSMOBILE    CUTLASS CRUISER    (1980 - 1981)
OLDSMOBILE    CUTLASS CRUISER BROUGHAM    (1980 - 1981)
OLDSMOBILE    CUTLASS LS    (1980 - 1981)
OLDSMOBILE    CUTLASS SALON    (1979 - 1980)
OLDSMOBILE    CUTLASS SALON 442    1979
OLDSMOBILE    CUTLASS SALON BROUGHAM    (1979 - 1980)
OLDSMOBILE    CUTLASS SUPREME    (1979 - 1981)
OLDSMOBILE    CUTLASS SUPREME BROUGHAM    (1979 - 1981)
OLDSMOBILE    CUTLASS VISTA CRUISER    1979
PONTIAC    GRAND AM    (1979 - 1980)
PONTIAC    GRAND LEMANS    (1979 - 1981)
PONTIAC    GRAND LEMANS LE    (1979 - 1981)
PONTIAC    GRAND LEMANS SA    1981
PONTIAC    GRAND LEMANS SAFARI    (1979 - 1981)
PONTIAC    GRAND PRIX    (1979 - 1981)
PONTIAC    GRAND PRIX BROUGHAM    1981
PONTIAC    GRAND PRIX LJ    (1979 - 1981)
PONTIAC    GRAND PRIX SJ    (1979 - 1980)
PONTIAC    LEMANS    (1979 - 1981)
PONTIAC    LEMANS SAFARI    (1979 - 1981)
TMessick is offline
post #7 of 10 (permalink) Old Apr 22nd, 09, 11:10 AM
steve
why not just delete the booster all together? i've seen lots more custom cars doing this lately and am thinking about it myself once i get my new brake kit.
317millhand is offline
post #8 of 10 (permalink) Old Nov 23rd, 09, 12:37 PM
Andrew
Send a message via AIM to Toreadorranger
im bumping this thread, with a question. I just picked up a stock 72 Abody brake setup minus the master/booster. I will be going with a BB eventually so I would like to get a booster that will clear. Are the dual-diaphram boosters listed below a bolt on job or is it a mix/match or modify my stock booster bracket to get it to work?
Code:
Toreadorranger is offline
post #9 of 10 (permalink) Old Nov 24th, 09, 11:07 PM
T
Well, my info was just a lookup of the info on the booster that Steve (Vrooom3440) referenced. I don't know if it's a direct bolt-up or if some tweaking is necessary to make it work...
TMessick is offline
post #10 of 10 (permalink) Old Nov 25th, 09, 2:24 PM
It was a bit of mix and match for me See my previous post.
You may be able to find just the brackets on Ebay or something...
This Thread is more than 2740 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
