69 steering collapsable tubes - Chevelle Tech
post #1 of 2 (permalink) Old Nov 2nd, 08, 7:44 AM Thread Starter
I pulled my steering column out and totally disassembled it and replaced bearings. It is a 69 non-tilt 4 speed. I broke the plastic tabs on the collapsable tube that the steering shaft goes through. I re-set the length of the collapsable tubes to what I believe is the correct lenght, 28" end to end. When I completed the assembly and installed the snap ring at the top of the steering shaft, I had to push the steering shaft all the way to the top and totally compress the spring at the bottom of the steering column lower bearing. What have I screwed up? Should I shorten the 28" length of the collapsable tubes?
Thanks,
JJ
99fatboy is offline
post #2 of 2 (permalink) Old Nov 2nd, 08, 8:53 AM
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
Re: 69 steering collapsable tubes
Sounds about right, its not easy getting that snap ring on seems almost its a 2 person job.
I started with Nothing and still have All of Nothing!
Bad Brads 1969 Convertible SS
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
1badss396 is offline
This Thread is more than 3160 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
