Front brake hose install...do you do it this way?? - Chevelle Tech
post #1 of 5 (permalink) Old Jul 26th, 07, 8:41 AM Thread Starter
I yanked all of the braking components out of the front of my '71 from the master to the wheels in order to replace everything with new. I have the GM service manual which I read for this procedure and it stresses the importance of fitting the front brake hoses on the car with the wheels on the ground for the purposes of getting proper hose alignment so that it won't twist, kink, etc. Obviously the car is up on jackstands with all 4 wheels off and torn apart. Is this the way most people do it or do you simply install the hose with the car off the ground taking care not to introduce any twist to it while mounting? Thanks!
___________________________________
'71 Chevelle; stout 355/TH350 (full manual)/12 bolt posi, 4.11
dpvoiceguy is offline
post #2 of 5 (permalink) Old Jul 26th, 07, 8:47 AM
Re: Front brake hose install...do you do it this way??
I just put them back like they were before
post #3 of 5 (permalink) Old Jul 26th, 07, 9:42 AM Thread Starter
OK...but let's just suppose that you weren't astute enough to read the book BEFORE removing the hoses and you don't know how they were in there? (translation...I'm a moron!) Now what?
post #4 of 5 (permalink) Old Jul 26th, 07, 9:52 AM
Assuming that you have the correct hose, they're pretty hard to get on wrong but I suppose you could let the car down and double check to see if they look like they might stretch too tight.
I would think that with the vehicle jacked up that is as tight as they would ever be but you could turn the wheels from one extreme to the other and visually inspect them.
post #5 of 5 (permalink) Old Jul 26th, 07, 11:33 AM Thread Starter
Thanks, Dean. I was thinking the same thing. I figured that was the best I could do at this point. The hoses were ordered from the parts store as being for this car and they line up exactly to the old ones. I am confident I've got the right parts. I will simply take my time, turn it lock-to-lock, and look for any potential concerns.
This Thread is more than 3623 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
