Brake booster replacement - Chevelle Tech
post #1 of 2 (permalink) Old Mar 22nd, 07, 3:32 PM Thread Starter
On my 69 Chevelle, previous owner painted the entire brake booster resorvior and all. It's not bad, brakes are good but I want the natural look. If I replaced the unit as a whole, how hard is it ?
Drain the resorvior, unbolt, bolt in new ? Would the system have to be bled.
Thanks.
larietrope is offline
post #2 of 2 (permalink) Old Mar 22nd, 07, 3:57 PM
Rob
Re: Brake booster replacement
Easy fix, but you will need to bench bleed the master before you put it on, then bleed the whole system starting with the wheel furthest from the master.
Time consuming, but easy job, as long as you don't run into any other problems (stripped bleeders, etc.)
Hope that helps..
Rob
496, 10:1, Brodix RR-Os, Lunati HR 60212, Air Gap, prosystems 950HP
The 71 Chevelle
kacp-o is offline
This Thread is more than 3748 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
66 elky power brake booster mr.stew El Caminos 1 Oct 15th, 05 12:26 PM
brake issues, what I've done and going to do, any suggestions no1dc Brakes, Suspension & Steering 7 Oct 13th, 05 2:45 PM
New brake kit- bad booster??? CRUZN68 Brakes, Suspension & Steering 6 Sep 7th, 05 12:56 AM
Brake fluid in the booster MikeD70Malibu Brakes, Suspension & Steering 2 Jul 29th, 04 11:09 AM
Brake booster and master cylinder for a 68 Sem Brakes, Suspension & Steering 2 Oct 26th, 03 11:26 PM
