LS1 REAR BRAKE CONVERSION/proportioning valve - Chevelle Tech
post #1 of 1 (permalink) Old May 23rd, 06, 10:20 PM Thread Starter
Question LS1 REAR BRAKE CONVERSION/proportioning valve
I HAVE A 1971 cutlass supreme convertible [ A-BODY ]
the factory set up is power disc up front and drum rear
i want to use the rear disc brakes off a late model camaro 1998-2002
LS1 CAR can i use my factory combination valve or do i need to install a proportioning valve if leave the factory set (combination valve)up on will this still work?
724tim is offline
This Thread is more than 3992 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
1970 Brake system expert needed! SMS Brakes, Suspension & Steering 3 Mar 13th, 06 9:34 PM
64 rear Brake line size.... jrb56 Brakes, Suspension & Steering 4 Sep 1st, 05 5:05 PM
LS1 engines & single valve springs Tokyo Torquer Performance 2 May 2nd, 05 2:24 PM
Looking for some rear disk brake advice ddoud Brakes, Suspension & Steering 7 Dec 6th, 04 7:20 AM
Not Chevelle, but Mostly Chevy-- Brake Bleeding Saga Continues (Long Post) odie Brakes, Suspension & Steering 5 Jun 21st, 03 11:13 PM
