67 gto front drum spindle/hub assembly - Chevelle Tech
post #1 of 7 (permalink) Old Oct 31st, 05, 1:03 AM Thread Starter
Jason
Send a message via Yahoo to 136679ss
will a gto front spindle work on the same year chevelle and vice versa 67 model year, drum brakes. I am thinking yes but would like an expert 2nd opinion. thanks in advance jason.
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #2 of 7 (permalink) Old Oct 31st, 05, 8:50 AM
"The Stig"
Re: 67 gto front drum spindle/hub assembly
Yes, same parts.
Derek69SS is offline
post #3 of 7 (permalink) Old Oct 31st, 05, 9:28 PM Thread Starter
Jason
Thanks Derek, the steering arms have to be different though I would think since Moog lists different part numbers for the centerlink? What say you. thanks Jason.
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #4 of 7 (permalink) Old Oct 31st, 05, 9:40 PM
"The Stig"
The steering arms should be the same too.
I'm not sure why the centerlink is listed different Are you sure one wasn't listed as having Power Steering or something?
post #5 of 7 (permalink) Old Oct 31st, 05, 11:59 PM Thread Starter
Jason
power steering centerlink same as non power. difference is the pitman arm.
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #6 of 7 (permalink) Old Nov 1st, 05, 7:16 AM
If it's done the same way as on later models, the only difference in the steering linkage is in the diameter of the outgoing shaft on the steering box. A P/S box has a larger shaft, but the arm is the same length as on a manual box. All other parts are the same, such as ball joint dimensions, geometry etc.
1969 Malibu in progress
Olle is offline
post #7 of 7 (permalink) Old Nov 7th, 05, 10:46 PM
I'm not sure about the US cars, but the Canadian cars do indeed have 2 different diameter (13/16" or 7/8") center links from 64 to 67. As long as all the components are matched, you can use either one. I think Cutlass is also a hit and miss deal with the center links. It may only be the Canadian cars that are that way though.
Carl
Carl S is offline
This Thread is more than 4219 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
700R4 and 2004R Transmissions G.M Transman Transmission & Driveline 81 Jul 13th, 07 12:55 AM
New Pontiac GTO on the way 00WS6TA Bench Racing 27 Aug 2nd, 05 6:46 PM
Front light assembly for 71' malibu malibu350 Body Shop 1 Mar 23rd, 01 8:16 PM
