in
this forum
in
the entire site
Cancel
Login / Join
What's New
Forum Listing
Products
Marketplace
Showcase
Gallery
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Chevelle Mechanical
Brakes, Suspension & Steering
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 685
Go to page
Go
685
G
Sticky
1964-1972 Chevelle Camaro Rear Disc Brake Conversion or 11 inch Rear Brake Drum Conversion
Gary 396
Dec 2, 2022
7K
Mar 9, 2024
by
Gary 396
G
Sticky
Rag Joint, Chevelle Tilt & NonTilt Steering Column, Rag Joint replaced by, Steering U Joint, U Joint Steering Shaft Facts, Ididit Push Button Start
Gary 396
Nov 26, 2022
11K
Mar 9, 2024
by
GM man
6
Sticky
Jeep box upgrade-PICS-and then some...
69307/350Chevelle
Oct 22, 2010
38
39
40
799
390K
Dec 5, 2023
by
Todco
Sticky
PST Front End Kit install, dialup warning
Tom Mobley
Jun 2, 2009
5
6
7
121
131K
Feb 17, 2023
by
jeffs68
G
Sticky
Comfort Grip, Wood Steering Wheels, Chevelle Corvette Camaro, 3 Steering Column Hubs, Turn Signal Replace Links, Leather Steering Wheels 14"
Gary 396
Dec 4, 2022
12
4K
Dec 6, 2022
by
MTN64
7
Sticky
Ball joint snapped in offshore tubular control arm!!!
72ragtop
Apr 5, 2013
4
5
6
109
99K
May 24, 2022
by
cv67
Sticky
Disc Brake Conversion basics
Derek69SS
Nov 4, 2005
79
287K
May 16, 2021
by
69nomad350
G
Sticky
Rear suspension for drag racing: Optimal Instant center location requirements
GR8WHITE
Feb 2, 2021
Locked
4
5
6
107
40K
Feb 23, 2021
by
Tom Mobley
M
Sticky
Any adjustment in booster pin?
MJRIBEIRO
Apr 14, 2008
52K
Oct 16, 2020
by
temp2c
S
Sticky
My new How To video on Boxing Rear Lower Control Arms
SS70ElCaminoOwner
Mar 26, 2019
16
12K
Jul 9, 2019
by
adamsmith
Sticky
Make your own BB 66 power steering pump!
CoolBlueGlow
Aug 23, 2012
8
27K
Nov 19, 2013
by
Texas70
G
Sticky
Spring Removal - Step By Step - With Pictures
Greg
Feb 24, 2009
Locked
61
127K
Oct 29, 2010
by
Greg
J
Sticky
A & F-car tilt column papers
JIML82
Dec 25, 2009
Locked
32K
Dec 28, 2009
by
Dean
Need New Spindles
BobinPA
Dec 30, 2023
25
857
8h ago
by
BobinPA
K
Adjustable proportioning valve question.
kljones
1d ago
15h ago
by
pannetron
Lower ball joint replace-LCA will not lower
budsthe3
1d ago
14
324
16h ago
by
Gary56
4
70 chevelle spindles
454bbss
3d ago
5
267
1d ago
by
454bbss
Brake pedal fades off
rouxster70
Feb 25, 2024
12
504
2d ago
by
rouxster70
B
CPP C5 spindles with 13 inch rotors 72 Malibu
beason68
3d ago
1
90
2d ago
by
Jasons 69 Chevelle
I
Classic Performance PTK-4 68-72 | Tubular Control Arms
ItzTheDay
Feb 14, 2024
30
1K
3d ago
by
Jasons 69 Chevelle
4
70 chevelle steering wheel lock bolt
454bbss
3d ago
0
121
3d ago
by
454bbss
4
70 chevelle steering gear pittman arm
454bbss
5d ago
7
200
4d ago
by
weidhopper
Horn contact on GM comfort grip steering wheel
Carguy222
5d ago
13
216
4d ago
by
mr 4 speed
are tubular A-arms worth it?
Squaredriver
Mar 10, 2024
41
2K
6d ago
by
Kopfjaeger
T
Front End Alignment Specs - Redo? Did they screw up?
Tomb7us
Mar 11, 2024
13
436
6d ago
by
Jim's69Ragtop
Looking for front disc conversion kit suggestions...
bertman72
Mar 10, 2024
25
558
7d ago
by
mrpaticular
P
Steering wheel off-center after power steering and suspension upgrades - where to troubleshoot first?
perfect
Mar 11, 2024
8
297
Mar 11, 2024
by
RifRaf
M
Here we go!
mvidal1966
Mar 6, 2024
6
289
Mar 9, 2024
by
Freddy Mercado
S
1970 proportioning valve confusion
Stetson Steiger
Jan 24, 2020
6
4K
Mar 9, 2024
by
ekitch
I
Need to find new manual steering box.
IROCJOE
Mar 5, 2024
11
387
Mar 7, 2024
by
Myanmar1
O
Bleeding Brakes
O'Man
Mar 6, 2024
12
372
Mar 6, 2024
by
oldcutlass
1967 power steering pump housing leak
Peteyk
Feb 26, 2024
Mar 5, 2024
by
Peteyk
Steering shaft header clearance
mrpaticular
Mar 4, 2024
0
116
Mar 4, 2024
by
mrpaticular
CVF PS Pump specs vs. CPP Hydrastop specs.
65conv
Mar 3, 2024
4
186
Mar 4, 2024
by
rmc65elco
UMI Boxed Premium Lower Rear Control Arm Recessed Grease Fitting
Rickles
Mar 2, 2024
8
318
Mar 4, 2024
by
Rickles
C
Power steering hose adapters
ChevelleBrad
Mar 2, 2024
14
362
Mar 3, 2024
by
lucifershammer
Looking for suspension work in Dallas
flhhc
Mar 3, 2024
0
111
Mar 3, 2024
by
flhhc
B
Brake conversion help
Boneshaker8
Feb 28, 2024
8
333
Mar 2, 2024
by
David Bates
Master cyl upgrade
ScottHunka
Feb 28, 2024
4
365
Feb 29, 2024
by
123pugsy
P
Added Power Steering for my 67SS - steering wheel jerking while turning?
perfect
Feb 27, 2024
9
374
Feb 28, 2024
by
COPO_68
K
Electric Vacuum Pump Installation Write-Up
Ki_Power
Feb 26, 2012
9
13K
Feb 26, 2024
by
Jus-Cruisin
Lifting rearend
6T7 SS
Feb 17, 2024
2K
Feb 25, 2024
by
Jus-Cruisin
clocking steering wheel
mrjay53
Feb 22, 2024
7
351
Feb 23, 2024
by
658Chevy
65-68 BB P/S reservoir location
64SS427
Feb 15, 2024
12
503
Feb 20, 2024
by
64SS427
F
Front Disc brake conversion
Freddy Mercado
Jul 13, 2023
4
753
Feb 18, 2024
by
Lew540
T
Steering Wheel Capsules - Sources
Tomb7us
Feb 14, 2024
7
355
Feb 17, 2024
by
1971-Chevelle
T
Violent wheel hop vs. Pinion angle adj.
TUFF71
Jun 21, 2010
13
7K
Feb 17, 2024
by
Badd64
G
Power steering gear boxes
GM man
Feb 13, 2024
26
1K
Feb 17, 2024
by
pvkj454
1
1 of 685
Go to page
Go
685
165.1K
posts
48.3M
views
Conversion questions & more.
Show Less
Join Community
Grow Your Business
Forum Staff
View All
Bob Tiley
Super Moderator
Top Contributors this Month
View All
richiecat4223
lucifershammer
oldcutlass
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
Chevelle Mechanical
