Rear axle ratio from VIN - Chevelle Tech
post #1 of 11 (permalink) Old Oct 4th, 12, 10:03 PM Thread Starter
Greg
Does anyone know if its possible to find out my rear axle gear ratio from my chevelle's VIN number? I've been under the car too many times and theres just too much rust on the axle tubes to find anything. If it helps I have a 1970 chevelle 396/350 SS 4-speed. I'm pretty sure that its <3.31 because the previous owner said that the rpm's would let the car just "purr" at 60mph on the highway. Thanks.
-Greg
Greg.H is offline
post #2 of 11 (permalink) Old Oct 4th, 12, 11:00 PM
Re: Rear axle ratio from VIN
Bill Pritchard
69 SS396 Convertible L35 M40
69 SS396 'Post Sedan' L35 M20
"Life is short; eat dessert first." - Ogden Nash
Bill Pritchard is offline
post #3 of 11 (permalink) Old Oct 4th, 12, 11:17 PM Thread Starter
Greg
Originally Posted by Bill Pritchard View Post
Is there anywhere else that I can find it besides the rear axle assembly? I really dont want to try and crawl under there again just to come up with nothing.
Greg.H is offline
post #4 of 11 (permalink) Old Oct 5th, 12, 12:22 AM
Tom Lloyd
you could turn the axle and calculate the ratio. It seems that you want the original ratio though. Axle tube, build sheet, window sticker, protecto plate, sales paperwork.
Tom Lloyd
my 66
take my advice, I'm not using it.
floyd66 is offline
post #5 of 11 (permalink) Old Oct 5th, 12, 12:23 AM
You can get a ballpark number, by jacking the rear wheels off the ground, then turn the wheel one revolution, and count how many times the drive shaft turns. The best way is to pull the cover off and count the teeth on the ring and pinion gears. If it's that nasty under there, it's probably a good idea to pull the cover anyway, to change the gear oil.
Bill Rose is offline
post #6 of 11 (permalink) Old Oct 5th, 12, 1:16 AM
Joseph
If it has the original gear, most in likely it is a 3.31 if you have a real L34 car. Jack the car up and use a scotch brite pad. You can find it.
Joseph
TC# 5427
ACES# 7460
1972 Chevelle SS 454 LS5 "W" Code Convertible
Sequoia Green White Top and Interior
http://i271.photobucket.com/albums/j...skqv2zuon.jpeg
1970 Chevelle SS 396 "L78" 4 Speed Coupe
Black with Black Bucket Interior
http://i271.photobucket.com/albums/j...JoesL78015.jpg
1970 Chevelle SS 454 LS6 Coupe
Forrest Green with Green Bucket Interior
http://i271.photobucket.com/albums/j...srmc0afs8.jpeg
1972convss454 is offline
post #7 of 11 (permalink) Old Oct 5th, 12, 10:15 AM Thread Starter
Greg
Thanks guys, I think I'll try counting the turns of the driveshaft to one turn of the wheel, but I may also change the gear lube since the car is completely stock and it has most likely never been changed.
Greg.H is offline
post #8 of 11 (permalink) Old Oct 5th, 12, 10:42 AM
& Administrator
You have a 42 year old car/rear.
Might be time to replace the gear lube so I'd drop the cover and get the numbers off the ring gear during the needed lube change.
uıɐbɐ ʎɐqǝ ɯoɹɟ pɹɐoqʎǝʞ ɐ buıʎnq ɹǝʌǝu ɯ,ı
Mike is offline
post #9 of 11 (permalink) Old Oct 5th, 12, 1:01 PM
-Greg
I have the same setup (396/350 hp with 3.31 rear end) and at 60 mph on the freeway it is more of a "roar" than a purr. It's totally looking for a higher gear.
ACES #07817
1969 Daytona Yellow SS396
jbarberggd is offline
post #10 of 11 (permalink) Old Oct 27th, 12, 4:31 PM Thread Starter
Greg
I finally came home and had some time to check out the car. When I jacked up the car and turned the wheel one revolution, the driveshaft only turned 1 1/2 times around. I know that this isn't a very precise way to find the rear axle ratio, but there's no way it can only be 1.5:1. Does anyone know why this happened?
I also went under with some sandpaper and tried to find the code on the axle tube. I looked on the rear passenger side of the tube, is this the right place? Thanks for any help.
Greg.H is offline
post #11 of 11 (permalink) Old Oct 28th, 12, 10:23 AM
Dale
Correct location is the front side of passenger side axle tube. GM says 8" inboard from the backing plate but that's a guide. As noted 3.31:1 would be typical for a 396/350 and should start with CCW then a 4 character date like 1025.
DaleM is offline
This Thread is more than 1701 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
