12 bolt codes / casting numbers and rear axle ? help - Chevelle Tech
post #1 of 15 (permalink) Old Jan 27th, 12, 7:00 PM Thread Starter
OLIVER
Hello guys, i crawled under the car , cleaned the housing found some codes , i need some help please to de-code-i did a search on the web but i can come up with nothing certain... so here are the numbers ;
looking from the back at the 12 bolt housing
(driver side) top left 12 on top and 67880 just below
(passenger side) bottom right corner 55 L 4 8 or B
the only thing I decoded is L 4 8 - could be december 4 th 1968 , correct ? 55 ?
i ve been tryng to find the rear axle codes in order to find out the gear ratio but this code should be on the other side of the rear shaft , so i guess i need to raise the car somehow to find those numbers
thanks for any help...
Oliver
Milano , ITALY
468 Vortecpro 585 HP
M20 4 speed - 4.10s
Prosystems 1000
ACES # 09607
BEST ET 11.62
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
https://www.youtube.com/watch?v=HS1ynhb5QBg
https://www.youtube.com/watch?v=k_p-GQl4gpE
oliver69 is offline
post #2 of 15 (permalink) Old Jan 27th, 12, 7:15 PM
& Administrator
Re: 12 bolt codes / casting numbers and rear axle ? help
http://chevellestuff.net/qd/generic_rear_axle_info.htm
http://chevellestuff.net/qd/all_axle_codes.htm
uıɐbɐ ʎɐqǝ ɯoɹɟ pɹɐoqʎǝʞ ɐ buıʎnq ɹǝʌǝu ɯ,ı
Mike is offline
post #3 of 15 (permalink) Old Jan 27th, 12, 7:25 PM Thread Starter
OLIVER
Hi , yes... This is where i was looking and i decoded - L 4 8
but the other numbers i have are not there or maybe i m not finding them .... nor the axle codes
Oliver
Milano , ITALY
M20 4 speed - 4.10s
Prosystems 1000
ACES # 09607
BEST ET 11.62
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #4 of 15 (permalink) Old Jan 27th, 12, 7:28 PM
& Administrator
The housing code and location is in the first link and the axle codes are in the second link -posted by year.
Some of the numbers you posted are just foundry marking and don't mean anything to the end user.
Mike is offline
post #5 of 15 (permalink) Old Jan 27th, 12, 7:47 PM Thread Starter
OLIVER
Mike thanks , so those numbers are just foundry numbers... so in the following link there is the " codes location " but i scraped and cleaned i found nothing... could it be its on the other side ?
http://www.chevelles.com/years/69/69rearcodes.html
Oliver
Milano , ITALY
M20 4 speed - 4.10s
Prosystems 1000
ACES # 09607
BEST ET 11.62
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #6 of 15 (permalink) Old Jan 27th, 12, 8:05 PM
& Administrator
Look on the front of the passenger side axle tube for the code about half way between the center section and the brake backing plate..
Didn't realize Dale was showing it on the back of the tube ,close to the center section.
I wouldn't trust the code to be what's inside a 43 year old rear ,I'd pull the cover and get the gear info.
The rear could probably use a lube change after 43 years
Mike is offline
post #7 of 15 (permalink) Old Jan 27th, 12, 8:17 PM
Hi Oliver,
With a Foundry Date of December 4, 1968, your Casting Number should be 3917124.
Tory
ACES Member #1890
Team Chevelle Gold #288
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS
1966 Chevelle SS 396 Unrestored 76,000 Mile Survivor
1968 Camaro
1968 Malibu L-79, 1 of 4082 ~ SOLD
1984 Hurst Olds w/ Factory Sunroof, 1 of 99 ~ SOLD
1985 442 White / Grey w/ Factory Sunroof ~ SOLD
Lionel-n-Chevelles is offline
post #8 of 15 (permalink) Old Jan 27th, 12, 8:32 PM Thread Starter
OLIVER
I guess i have to take the car to the garage i think its impossible to crawl under to look at the front side of the shafts ... but anyway thanks for the help .. and let you know if i find anything... ciao
Oliver
Milano , ITALY
M20 4 speed - 4.10s
Prosystems 1000
ACES # 09607
BEST ET 11.62
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #9 of 15 (permalink) Old Jan 27th, 12, 11:53 PM
Send a message via Yahoo to 71malibu400
X2!
TC #3738
ACES #07845
Lower Bucks AACA
PACC-Pa Chevelle club
71 Malibu 400 402BB 17,600 original miles
71 GMC Sprint
71malibu400 is offline
post #10 of 15 (permalink) Old Jan 28th, 12, 12:54 PM
Dale
The link, http://www.chevelles.com/years/69/69rearcodes.html , is here on TC, not my website.
I do have a rear end from a 67 Chevelle showing the stamped location at http://chevellestuff.net/qd/generic_rear_axle_info.htm however.
DaleM is offline
post #11 of 15 (permalink) Old Jan 28th, 12, 12:59 PM
& Administrator
Sorry for the mis-direct Dale.
Mike is offline
post #12 of 15 (permalink) Old Jan 28th, 12, 1:09 PM
Dale
DaleM is offline
post #13 of 15 (permalink) Old Jan 28th, 12, 4:47 PM Thread Starter
OLIVER
Dale, sorry i m getting confused - where are the codes on back or on front side of the tube ? - passenger - left side- looking at the car from the back
I scrubbed really hard on the back but have not found any ...
Thank you for the help
Oliver
Milano , ITALY
M20 4 speed - 4.10s
Prosystems 1000
ACES # 09607
BEST ET 11.62
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #14 of 15 (permalink) Old Jan 28th, 12, 4:58 PM
Dale
{edit - added photo}
The STAMPED codes are suppose to be on the passenger side front of the axle housing. These are not gang stamped and they're often not real deep either. GM parts book says they should be 8"-10" inboard of the backing plate but GM (itself) often didn't stamp them so there's no real measurement to go by. As you can see from teh photo I have of the 67 on that page, the stamping is more towards the center section but that's just from that person, that day, at that plant.
Again, road grime and paint from someone wishing to spruce up the looks underneath can make it hard to find.
DaleM is offline
post #15 of 15 (permalink) Old Jan 28th, 12, 5:03 PM Thread Starter
OLIVER
Great Dale, all is clear now..I ll try to find them ...have nothing better to do in rainy sundays anyway... Thanks again ciao
Oliver
Milano , ITALY
M20 4 speed - 4.10s
Prosystems 1000
ACES # 09607
BEST ET 11.62
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
This Thread is more than 1917 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
