what's this 396 from? - Chevelle Tech
post #1 of 5 (permalink) Old May 14th, 08, 4:08 PM Thread Starter
TIM BERNHARD
The #'s on the block are TO1IIET 18Z61819. This engine is in a 68 chevelle but doesn't match vin.
BERNHARD is offline
post #2 of 5 (permalink) Old May 14th, 08, 4:55 PM
& Administrator
Re: what's this 396 from?
Here's the choices:
ET 67 396 Chevelle 325 L-35 TH-400 4-Brl
ET 68 396 Chevelle 325 L-35 TH-400 4-Brl
As the partial vin shows an 8 ,kinda narrows it down.
Mike is offline
post #3 of 5 (permalink) Old May 14th, 08, 5:36 PM
Dale
I assume the number is stamped wrong or mistyped since the sequence number is only 5 digits but being a Fremont stamp, it'd have to be a 68 Chevelle as Mike noted.
DaleM is offline
post #4 of 5 (permalink) Old May 14th, 08, 5:59 PM
& Administrator
Could be why it doesn't match the VIN
Mike is offline
post #5 of 5 (permalink) Old May 14th, 08, 6:09 PM
Dale
That and being a early-mid January car by the engine date, the sequence should be in the high 120's range 128xxx, 129xxx. Kinda suspect. Even if it was 161819 that'd be mid July.
DaleM is offline
