72 402 Block With 3999289 Casting # ????? - Chevelle Tech
post #1 of 9 (permalink) Old May 6th, 08, 9:27 PM Thread Starter
Just bought a 1972 454 block, casting # 3999289. The guy told me it was a 402 and gave me the casting # 3999289 (72-75 454), not the 1972 402 casting # 3999290. I got there looked at the casting# 3999289, then the date JUNE-72, then looked at bottom side it was cleared for 4" 454 crank, looked at the deck and it was stamped CTB 402 240HP, I then miced the block, the guy said he just bored it .030 over and the bore was 4.155 a .030 over 402 bore. Has anyone ever seen a 454 block with a 402 4.125 bore?????
67 Chevelle SS Marina Blue
66 Malibu (soon to be SS 375HP clone)
67SS Royal Plum original paint
supersport6667 is offline
post #2 of 9 (permalink) Old May 7th, 08, 10:41 AM
Dale
Re: 72 402 Block With 3999289 Casting # ?????
Bore definitely too small for a 454. Maybe Tonawanda just used a 454 casting and bored it for a 402 application. Apparently the suffix code bears this out. Odd...
DaleM is offline
post #3 of 9 (permalink) Old May 8th, 08, 7:21 AM
My '69 SS has a 454 block with the 3999289 casting number. It is bored .030 over.
Where on your block did you find the JUNE 72?
'69 Chevelle SS, Olympic Gold/Black
TC #3666
ACES #7801
Chevelle Club of Michigan
arkitekt1 is offline
post #4 of 9 (permalink) Old May 8th, 08, 9:53 AM
You must nave a 402 and not a 454...
CTB = 402
CTB 1972 396 240 Camaro LS-3 AR
CTB 1972 402 240 Camaro LS-3 AR
CTB 1972 402 240 Chevelle LS-3 AR
CTB 1972 402 210 Chevrolet LS-3 AR
CTB 1972 396 210 Chevrolet LS-3 AR
CTB 1972 396 240 Chevelle LS-3 AR
WILD72 is offline
post #5 of 9 (permalink) Old May 8th, 08, 9:58 PM
Chevelle Doctor
Bore it another tenth and make it a 454!
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #6 of 9 (permalink) Old May 9th, 08, 11:11 PM Thread Starter
The block is a 454 block according to the casting number, but it left tonawanda as a 1972 402 or it wouldnt have been stamped with the CTB code and the block has a vin # on the deck. The guy I got it from said it was STD bore (4.125) when he got it and he rough bored it to 4.150. Its just odd they used the #289 casting block for the 402 instead of the correct #290 casting block. The casting date is on pass side backside of block. If this block left the plant this way I'm sure there were others. Imagine having an original 69 396SS chevelle with a #512 block instead of a #272 block, would have a hard time trying to prove block wasnt a restamp.
post #7 of 9 (permalink) Old May 12th, 08, 6:58 PM
This is not the first time I have run into engines with casting numbers that were built as something other than their intended purpose. Friend of mine has a 71 #512 block that is also 402 standard bore and a 402 Suffix code. Oviously a factory mistake, anomoly, whatever word you want to call it, but it did happen. Also goes back to the fact that casting numbers were really only used to identify parts before they were machined. Afterwards, they were ID'd by the production stamp or part number of the part. Casting number is now no longer used by them as a reference, since it can be machined different ways i.e.... Can be made into a 2- bolt, or 4-bolt block. Casting numbers are a great reference for us to use, but the part must always be checked to see if it was machined to that application, or used for something different.
Jeff Dotterer
Dated Components
Diamond Restored Judge
Diamond Judge1 is offline
post #8 of 9 (permalink) Old May 12th, 08, 7:56 PM
The big block ID list on nastyz28.com shows 3999290 as a '72 402. Could it be the block was stamped incorrectly?
TC #3666
ACES #7801
post #9 of 9 (permalink) Old May 12th, 08, 11:39 PM Thread Starter
Block is a 454 block, it just wasnt bored 4.250 from factory it started life at 4.125. I am going to bore block again to 4.250 as I have some std 454 pistons been wanting to use for sometime and dont really feel the block as any collector value.........
This Thread is more than 3270 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
