chevy cylinder head casting date M 49 Need help!! - Chevelle Tech
post #1 of 7 (permalink) Old Apr 5th, 08, 1:40 PM Thread Starter
Walter N
Im trying to figure out why a head that i have which is a 3927186 302 dz head original 2.02/1.6 camel back head has a casting date of M 49, the other is d 29 9, which is more clear...anyone know the answer...thanks in advance.
69chevelleX2 is offline
post #2 of 7 (permalink) Old Apr 5th, 08, 2:39 PM
& Administrator
Re: chevy cylinder head casting date M 49 Need help!!
Somewhere along the line a head may have been replaced.
BTW ,theres no way to validate the DZ application as you keep posting it.
Those heads came on more than just the 302:
3927186....69-70...302/350......Camel hump,64cc chambers,accessory holes
Mike is offline
post #3 of 7 (permalink) Old Apr 5th, 08, 8:41 PM Thread Starter
Walter N
Well, i do know these are the dz code heads for the correct dz engine because i took these off that engine a long time ago from a wrecked camaro.. thats why i know, they have been in the family for about 15+ years. till i upgraded to aluminums.thanks i need to know why this one is stamped M 49
post #4 of 7 (permalink) Old Apr 5th, 08, 10:36 PM
Jon N.
I read somewhere that M castings were run as test castings, and if they were o.k. they were machined and used like normally dated castings. Might have been on camaros.org.
Jon N.
dyno jonn is offline
post #5 of 7 (permalink) Old Apr 7th, 08, 12:29 AM Thread Starter
Walter N
I have checked out the camaro.org and it says that only blocks were coded with M, does that mean blocks only or does that same thing go for heads...would these be same or more valuable than others, like i said these heads came off the exact same engine and it was off a camaro 69 or 68 cant remember, with a manual transmission... I would say its really something that gm did after they tested them instead of throwing them away they placed them in production just like that site says.
post #6 of 7 (permalink) Old Apr 7th, 08, 5:44 PM
I have a water pump that also carries M as the month code. It is cast M-XX-8. I do not know if it was the test situation as stated on the Camaro site, or if that was just a guess. Could also have been some form of a mistake. So far the only items I have seen in 20 years have been related to this exact period of Flint built small blocks.
Jeff Dotterer
Dated Components
Diamond Restored Judge
Diamond Judge1 is offline
post #7 of 7 (permalink) Old Apr 8th, 08, 12:01 AM Thread Starter
Walter N
I guess it really is hard knowing what these M coded parts really are.. Would these heads i have, have the same value as other coded pair of heads from the 302 dz, or do people really go for the castings instead of the date codes. I was thinking of getting rid of these but im not yet sure, if the m coded head i have is really a piece that made it out of the foundery i would like to keep them since that would really mean something special, meaning a real history about chevys past production activities.
This Thread is more than 3305 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
