Rearend Decode? - Chevelle Tech
post #1 of 7 (permalink) Old Feb 23rd, 07, 7:58 PM Thread Starter
Rearend Decode?
I know it's a 12-bolt, but not sure from what.
Looks like the housing is #3968038
Axle tube: TEL -0526K- Left axle Tube
ACES Member
71 Chevelle - Who cares about the paint. You won't see it long anyway.
LS1/T56 swap - On the Street!!
For Sale: '71 Complete A/C PM Me
stealth71 is offline
post #2 of 7 (permalink) Old Feb 23rd, 07, 8:37 PM
Re: Rearend Decode?
I know one thing, the number of the casing is 3959038, it may appear as 3958038 but it is not and this would be a 1969 housing. go to www.chevellestuff.com then click "decoding" then rear and you can scroll down and see what I am stating. The TEI does not show as anything but the 0526K means the date stamped likely was 05=may 26 =26th and K =Mc kinnon plant. I am not a expert on these things so please do not take my word 100% , you may want to check it yourself or have one of the more knowledgable Guys on this forum check it out for you. GOOD LUCK --- BOB
"It's nice to be important but it is more important to be nice"
Realhummer is offline
post #3 of 7 (permalink) Old Feb 23rd, 07, 8:46 PM
Re: Rearend Decode?
I got my numbers a little confused here , YOU SAID IT LOOKS LIKE 3968038 and I meant to state that a 69 rear is 3959038 --- I stand corrected, Got myself a little twisted up on that ! BOB
post #4 of 7 (permalink) Old Feb 23rd, 07, 10:04 PM
Re: Rearend Decode?
I'm not sure what you mean by left axle tube, but if you mean driver's side, that's not where my 12 bolt is marked. My 12 bolt decoded "CI" from a 66-68 Chevelle. It is marked on the passenger side axle tube, on the driveshaft/pinion side of the tube. Mine was pretty difficult to see, as the stamping was no where near as deep a stamping as the one pictured here. I had to use a 220 girt sandpaper , then wash it with thinner to find the marks. It was early on after I bought this 72 parts car, and before I popped the cover. Pleasant surprise- decoded as a 3:73 gear with posi-traction- verified later after opening it up. Very happy to put it in my 71!
rcrchsr16 is offline
post #5 of 7 (permalink) Old Feb 23rd, 07, 10:33 PM
mr
Don
Wink Re: Rearend Decode?
Originally Posted by David_Bates View Post
Here are the casting numbers I have personally observed over the decades:
12-Bolt Housing: Casting #
1965 Chevelle 3859140N
1966 Chevelle 3875745N
1967 Chevelle 3894939NF
1967 Chevelle-Late 3917124NF
1968-Early 69 Chevelle 3917124NF
1969 Chevelle 3959038NF
1970-72 Chevelle 3969278NF
10-Bolt Housing: Casting #
1964 Chevelle 3839390N
1965 Chevelle 3959139N
1966 Chevelle 3875744N
1967 Chevelle 3894938NF
1968 Chevelle 3917123NF
1969 Chevelle 3859037NF
1970-72 Chevelle 3969277NF
"Chevrolet by the numbers 1965-69", does'nt list any "code", anywhere close, to the [Axle tube code: TEL 0526 K].... Don.
__________________________________________________
....... "drag racers do it , till their rubber smokes" .....
mr is offline
post #6 of 7 (permalink) Old Feb 23rd, 07, 11:28 PM
Re: Rearend Decode?
This is another one of the chevelle 12bolts used in the Canadian built
Cutlass 442 starting in 68 at Oshawa plant.
TL=In 69: Olds. 3.55 posi, the off set E is for Eaton posi source.
shooter is offline
post #7 of 7 (permalink) Old Feb 24th, 07, 12:06 AM Thread Starter
Re: Rearend Decode?
This rear was originaly from a different car and this confirms it. You sure know your stuff. Thanks for the quick responses.
ACES Member
This Thread is more than 3777 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Chevelle Rearend Decode kellyjohnm Tag Team 4 Aug 17th, 07 2:50 PM
rearend decode bc69ss Transmission & Driveline 2 Feb 22nd, 07 6:16 PM
Rearend Decode EverRude Tag Team 3 Feb 9th, 05 1:18 AM
Rearend Decode EverRude Transmission & Driveline 4 Feb 8th, 05 2:36 PM
Rearend decode vr1967 Tag Team 2 Jan 20th, 04 5:10 AM
