1966 SS - snail pace project - Page 4 - Chevelle Tech
 3Likes
post #46 of 172 (permalink) Old Feb 26th, 12, 11:07 PM Thread Starter
Tom Lloyd
Re: 1966 SS - snail pace project
and the other side. Then a test fit. I need to trim a little off the ends before welding in place. I ran out of time tonight to button it up.
Changing a dash in a 66 is not too hard as everything is pretty accessible.
ID:	50433   Click image for larger version
ID:	50435   Click image for larger version
Tom Lloyd
my 66
take my advice, I'm not using it.
floyd66 is online now
post #47 of 172 (permalink) Old Apr 25th, 12, 11:40 PM Thread Starter
Tom Lloyd
I have been busy. I dismantled the parts car and the floor is out and all the sheet metal has been separated. This was a lot of work.
I need to attach the middle floor to the rear section under the seat. This will take fitting from one side to the other and a cross floor weld.
Due to circumstances of original floor pieces and so that I have the least amount of cutting I will be installing the pieces in a particular order. For installation of the floor I will have to place the rear seat section in the car. Then place the middle section into the car. This is because I will pry the floor area open about 3/8 of an inch to slip the replacement floor in. I will then weld the two pieces together and then attach them to the car. Easy.
After removing the 4 door brackets from the rear floor I cut it to the seam I wanted. I then used the cut off to spray paint gold the seam onto the forward floor. I then placed the rear section on top and traced a black marker to indicate the cut line. I checked a couple times and then went for it.
After a few iterations for touch up, I am happy with the fit and it will now need to be sandblasted before installation.
Name:	1 66 floor Apr 2012 (5).JPG
ID:	52501   Click image for larger version
Name:	2 66 floor Apr 2012 (3).JPG
ID:	52502   Click image for larger version
Name:	3 66 floor Apr 2012 (29).JPG
ID:	52503   Click image for larger version
Name:	4 66 floor Apr 2012 (27).JPG
Name:	5 66 floor Apr 2012 (32).JPG
ID:	52505   Click image for larger version
Name:	6 66 floor Apr 2012 (34).JPG
ID:	52506   Click image for larger version
Name:	7 66 floor Apr 2012 (35).JPG
Tom Lloyd
my 66
post #48 of 172 (permalink) Old Apr 25th, 12, 11:41 PM Thread Starter
Tom Lloyd
one more pic
I had to cut it like this because I needed the distinctive wrinkles in the floor hump. I know, its a sickness isn't it?
Name:	8 66 floor Apr 2012.JPG
Tom Lloyd
my 66
post #49 of 172 (permalink) Old Apr 26th, 12, 9:41 AM
Jarrett
Very nice work, Tom! I know how difficult it is to make accurate cuts on contoured panels like that. I'm sure no one will know the floors were ever cut when you're done.
300Deluxe is offline
post #50 of 172 (permalink) Old Apr 26th, 12, 3:26 PM
Bill and Tracy
Very nice work... You gotta love it when somebody takes a perfectly good car and hacks it up like that...
I get paranoid just trimming small areas for speakers and upgrades... LOL
Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin'
'67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo"
'67 Cougar 289-A 4V/C4 the "Rustification"
'68 Cougar 5.0L Sequential Fuel Injected
'79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY!
screamin_67 is offline
post #51 of 172 (permalink) Old Apr 26th, 12, 4:57 PM
Greg
Floyd, that's quite a project. Good for you! Keep up the pix.
Greg
My 68 El Camino Malibu and my 68 El Camino SS. In 1968 I got my 1st 66 Chevelle SS. 30 years later, I got my 2nd. Both Chevelles are in the same location.
Greg P is offline
post #52 of 172 (permalink) Old Apr 29th, 12, 10:48 PM Thread Starter
Tom Lloyd
Thanks for the kind words fellas.
Did a test fit to make sure it went in like I imagined. I did, with a small hitch, there was a burr in the cross brace/floor socket. Once I figured that out and fixed it things went together as they should.
Name:	April 27 SS (10).JPG
ID:	52616   Click image for larger version
Name:	April 27 SS (21).JPG
ID:	52617   Click image for larger version
Name:	April 27 SS (26).JPG
ID:	52618   Click image for larger version
Name:	April 27 SS (31).JPG
Tom Lloyd
my 66
post #53 of 172 (permalink) Old May 5th, 12, 1:11 AM Thread Starter
Tom Lloyd
Welded in the dash today. It went in easy. I welded the gutter up a little more than GM did. This should use a little less seam sealer. Blue sure looks good with the red. Maybe I should go with blue interior.
Name:	May 4 SS (2).JPG
ID:	52785   Click image for larger version
Name:	May 4 SS (3).JPG
ID:	52786   Click image for larger version
Name:	May 4 SS (5).JPG
ID:	52787   Click image for larger version
Name:	May 4 SS.JPG
Tom Lloyd
my 66
post #54 of 172 (permalink) Old May 5th, 12, 1:20 AM Thread Starter
Tom Lloyd
Fixed the rear speaker hack job. Here is a couple pics. This probably took 16 hours to do because of the repairs to the patch pieces. I just could not find good parts to put in. Well the're good now.
Name:	Nov 2011 package tray.jpg
ID:	52789   Click image for larger version
Name:	Nov 2011 package tray (2).jpg
ID:	52791   Click image for larger version
ID:	52792   Click image for larger version
Name:	May 2 2012 SS (16).JPG
Name:	May 2 2012 SS (20).JPG
ID:	52794   Click image for larger version
Name:	May 2 2012 SS.JPG
Tom Lloyd
my 66
post #55 of 172 (permalink) Old May 5th, 12, 1:34 AM
Smile Re: 1966 SS - snail pace project
Looking good, Tom!
Are these photos posted full size somewhere? These middle-aged eyes need more detail.
David
http://www.cardomain.com/ride/307290...rolet-chevelle
davewho1 is online now
post #56 of 172 (permalink) Old May 5th, 12, 2:56 PM Thread Starter
Tom Lloyd
Originally Posted by davewho1 View Post
Looking good, Tom!
I hear you brother! My eyes have fallen off a cliff since I turned 40. Maybe I should start wearing welding goggles?
I don't have the pics posted elsewhere, too lazy.
Tom Lloyd
my 66
post #57 of 172 (permalink) Old May 5th, 12, 9:53 PM
OK. Maybe you could email me one of them full size? I'll PM you.
David
post #58 of 172 (permalink) Old May 10th, 12, 11:59 PM Thread Starter
Tom Lloyd
I finished the dash. Added some welding to the typical Chevelle rusting areas.
Closed the gaps with a body hammer, then welded it up.
Pic 2 shows the GM weld
Pic 3 shows the gaps hammered closed
Pic 4 is welded
Pic 5 is under the gutter spout
Pic 6 is welded, less seam sealer now.
I also put a large steel dowel in the gutter spout and tapped it down to put more of a down spout. Shouldn't hold water now.
Repeat for other side.
Name:	May 10 2012 SS (10).JPG
ID:	52938   Click image for larger version
Name:	May 10 2012 SS (12).JPG
ID:	52939   Click image for larger version
Name:	May 10 2012 SS (13).JPG
ID:	52940   Click image for larger version
Name:	May 10 2012 SS (15).JPG
Name:	May 10 2012 SS (18).JPG
ID:	52942   Click image for larger version
Name:	May 10 2012 SS (19).JPG
Tom Lloyd
my 66
post #59 of 172 (permalink) Old May 11th, 12, 12:08 AM
Elroy
You are doing some beauty work there Tom ! Keep it rollin !!
66138 is offline
post #60 of 172 (permalink) Old May 11th, 12, 12:13 AM Thread Starter
Tom Lloyd
Thanks Elroy, I'm following your build too.
This car has all kinds of issues, fixed one today.
The heater area on the firewall was flattened and a million pop rivets attached aluminum block off plates.
Very fortunately for me the lip on the heater hole and blower hole were only hammered flat and not cut off. I carefully hammer and dollied the lip back into place. Turned out good. I thought I might have to graft firewall parts from the other car.
I am finding that my favourite tool in the shop is a body hammer.
Name:	May 10 66 firewall pass.jpg
ID:	52944   Click image for larger version
Name:	May 10 The Chevelle misc 006 heater hole.jpg
ID:	52945   Click image for larger version
Name:	May 10 2012 SS (22).JPG
ID:	52946   Click image for larger version
Name:	May 10 2012 SS (23).JPG
Name:	May 10 2012 SS (26).JPG
ID:	52948   Click image for larger version
Name:	May 10 2012 SS (27).JPG
Tom Lloyd
my 66
