Fuel Set up - Chevelle Tech
post #1 of 11 (permalink) Old Apr 28th, 12, 11:58 AM Thread Starter
Robert
Fuel Set up
I got a 68 Chevelle that I converted to a LSX 376. Im worrying that I will need a sump pump in my tank for fuel. Anybody have any ideas? Im thinking 1/2 line will be fine. I have the stock tank that I want to run.... Thanks for the help.
priviteer249 is offline
post #2 of 11 (permalink) Old Apr 28th, 12, 3:23 PM
Re: Fuel Set up
you could get the McRobb 1/2" pickup
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #3 of 11 (permalink) Old Apr 29th, 12, 5:09 PM
Erik
Re: Fuel Set up
I'm running the Tanks Inc set up with the walbro 255lph pump. I have put about 500 miles on the set up and have run the tank pretty empty with no sputtering on turns, take offs or stops. It is a little on the loud side but it fit in my stock 64 tank with the only other modification needed was a little hammer time on the trunk floor where the drop in assymbly is. But this is only 3/8's fuel line.
YeahIgotAChevelle is offline
post #4 of 11 (permalink) Old Apr 30th, 12, 7:26 PM
Re: Fuel Set up
x2
1968 Chevelle SS clone 03 LQ4 6.0l, D1SC Procharger 14lbs,AIS Methanol Injection,TFS/TEA 220 heads, BTR Cam 231/242 .617/.595 111, RKT Built t56, Fully built 12 bolt with 3.73 gear. 658rwhp 575rwtq
http://ls1tech.com/forums/conversion...-ls-knife.html
GsxrDave is offline
post #5 of 11 (permalink) Old Apr 30th, 12, 10:42 PM
Re: Fuel Set up
I installed an inline pump above the original gas tank. The metal line from the sending unit to the pump is shaped like a sink trap this keeps fuel in the line to feed the pump on start up. If you mount the pump on the frame rail as close to the sending unit as possible make sure the pump is below the tank. Using the original line with a quick connect to the fuel rail. LT1
mdcamaro is offline
post #6 of 11 (permalink) Old May 1st, 12, 11:38 AM
Re: Fuel Set up
This?
http://www.robbmcperformance.com/pro...69_gmsend.html
member number 684
71' coupe project:
goal: 150+MPH, 9s driven to and from track, 275 front tire, 315 rear tire, 1000+HP
Build: 540cid, twin turbo, 4L80e, ...wait for it...
Heart of Dixie Chevelle Club
BB_Mike is offline
post #7 of 11 (permalink) Old May 1st, 12, 7:45 PM
Re: Fuel Set up
I installed a fuel pump and sending unit assembly from a 4th Gen. Camaro in my original tank. I've been running it for 3 years and no problems.
68chevelle355 is offline
post #8 of 11 (permalink) Old May 2nd, 12, 8:35 AM
Andy
Re: Fuel Set up
Are you a carburated LSX guy or an injected LSX guy?
Andy's Auto Repair is offline
post #9 of 11 (permalink) Old May 8th, 12, 1:15 PM Thread Starter
Robert
Re: Fuel Set up
Carb Eldebrock 850
post #10 of 11 (permalink) Old May 8th, 12, 3:48 PM Thread Starter
Robert
Re: Fuel Set up
This pump loud?
post #11 of 11 (permalink) Old May 13th, 12, 10:05 AM
Edd
Re: Fuel Set up
You will not need 1/2 fuel line, 3/8 will work fine.
Uppster is offline
