Sinister's LS Turbo build! - Page 41 - Chevelle Tech
post #601 of 694 (permalink) Old Jun 5th, 12, 8:57 AM
Re: Sinister's LS Turbo build!
Originally Posted by Sinister View Post
Joe, you are so right. I have everything running fat right now. The 5.3 does a nice job. What is crazy is I towed my chevelle with our 2006 Dodge Ram 3500 turbo diesel and averaged almost 20mpg's. Can't believe that I did better towing it than I would have driving it. lol
Only with oil gas (diesel) brother!
post #602 of 694 (permalink) Old Jun 9th, 12, 11:02 AM Thread Starter
Just thought I would update this thread. I wanted to post in the performance section so here is a link to the new thread I posted with my results last night. This thing is friggin amazing once it gets into boost!
http://www.chevelles.com/forums/show...=1#post3529013
Sinister is offline
post #603 of 694 (permalink) Old Jul 8th, 12, 10:24 PM
Aaron
No update telling us you melted a piston?
Lol
1971 Chevelle. 355, megasquirt efi. On3 7875 turbo. 4l80e, py3600, 355 gears. C5 brakes, SC&C stg2+, hellwig bars, 04-06 gto seats. 546rwhp/450rwtq with 28% converter slip on 18psi!
Little walk around video
http://youtu.be/D_B0B1RNmcc
BowtieAaron is offline
post #604 of 694 (permalink) Old Dec 22nd, 12, 10:24 PM Thread Starter
My cousin had an Edelbrock Pro Flo XT intake and we traded straight up for my Vic Jr. a while back. I just started the swap today. You may remember that I blew the first engine up back in July (I think). When I did the swap to the next 5.3 we had some issues trying to get it to run. I wasn't sure if it was the engine, cam, what? Finally, after several weeks of swapping cams, messing with the tune, etc.. It ended up being a turbo that got wasted when metal must have passed through it when the engine blew.
I wanted to keep the "budget" goal so I took a chance on a set of On3 70's that are $324 shipped to your door. Anyways, my tune is better than ever before and have run as much as 30lbs of boost on this current 180,000 miles. I have it turned down to 15lbs now. Since everthing is running pefectly right now I figured this was a good time to swap the intakes.
For the swap, I had to move my catch can from center of my firewall over to the far left side. The Pro Flo sits back pretty far. I personally think the catch can looks better on the left side. I went ahead and decided to re do my passenger side down pipe to look more like the drivers side. The brackets that hold down the fuel rails on my Vic Jr. DO NOT work on the Pro Flo. I am going to fab some brackets up. The Pro Flo actually sits lower than my Vic Jr and Tall elbow so I had to cut the intake pipe to the throttle body and modify it. Since I am doing that anyways, I plan to rotate it and put the BOV turned to the drivers side instead of the passenger. This way the top radiator hose isn't in the way. I also had to drill two of the holes for my UMI throttle body to fit.
Here is a picture of where I am at so far. As you can see it isn't finished but you can see the Pro Flo is going to look pretty sick when I get it all in there and cleaned up.
Sinister is offline
post #605 of 694 (permalink) Old Dec 23rd, 12, 10:24 PM Thread Starter
More Pro Flo pictures. Got everything set up, wiring harness tucked in nice, new brackets fab'd up for the intake. The intake actually sits lower than the Vic JR. Not taller, so I will have to do something else with my fuel regulator set up and also the intake pipe to the throttle body.
Name:	Pro Flo 1.jpg
ID:	59131   Click image for larger version
Name:	Pro Flo 2.jpg
Sinister is offline
post #606 of 694 (permalink) Old Dec 23rd, 12, 10:49 PM
Steve "Dirty"
modchevelle is offline
post #607 of 694 (permalink) Old Dec 24th, 12, 8:09 PM Thread Starter
Originally Posted by modchevelle View Post
No kidding!
Sinister is offline
post #608 of 694 (permalink) Old Dec 27th, 12, 10:21 PM Thread Starter
Still working on the engine bay. Just trying to make the compartment as clean and efficient as I can. Today I managed to make a bracket to mount my coil packs together and mount them to the fire wall. I purchased some 6" threaded rod 1/4", some nylon lock nuts, and some steel spacers that I slid over the rod to keep the coils at a good and stable angle.. I also got some tabs to mount the rods to. All of this was found at Lowes. For spark plug wires, I purchased a set of stock wires for a 1998 Chevy Truck with a 350. They were a perfect fit at the stock length.
There is probably a better place to mount these but it was simple to run the wires and never touch the manifolds or down pipes. It was also the best place for me so I could still connect the sensor from the pcm to the coil packs. Only got one side done but I think it turned out pretty good. I like being able to see the valve cover without the coil packs on there much better.
Sinister is offline
post #609 of 694 (permalink) Old Feb 4th, 13, 10:52 AM
Vinny Vince
Update Del!!!!
*11 C6, 6.2, 6spd
69-CHVL is offline
post #610 of 694 (permalink) Old Feb 14th, 13, 12:54 AM Thread Starter
Here you go:
It's been a while. I thought I would post a current shot with the New Pro FLo XT, all the hotside wrapped and sealed, the return fuel line with a heat shield sleeve, The cold side intake portion and blow off valve re positioned, Catch can re positioned and polished, firewall smoothed.
The power glide is in but the drive shaft yoke is too short. I also need to get a bracket to hook up the shifter, get the new Kirkey seats in and she is ready to go. One week until the track opens up. I think I can have it driving by Sunday.
I really like the way the pro flo looks and the down pipes and hot side all wrapped. That alone should keep my engine bay temps way down.
Name:	Pro Flo XT Install 13.jpg
Sinister is offline
post #611 of 694 (permalink) Old Feb 14th, 13, 7:06 AM
lookin good-i got way behind with my rotator cuff surgery, but back on it-72, 6.0, LS3 heads/intake, Procharger transplant kit
finished the rear quarters, working on the repo front fenders, cuttin, welding trying to make them fit-they must have been made for an Edsel, lol
using the old 6.0 shortblock from my 69 (swapped in a stroker) using the Holley HP EFI, it all plugs in, load a base tune, build out from there, i hope-learning exp. for sure
hoping Tanks, inc has the new FI tank out this month, looking for short cuts to get it finished right now, lol
not sure whats wrong with this site, slow as hell on my computer, and they dont seem to want to fix it, so i dont come on as offen, but i'll look for your post at the track-good luck, you have def stuck with it and made it work, pretty cool
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #612 of 694 (permalink) Old Feb 14th, 13, 7:41 AM Thread Starter
Thanks. I still have some items I am going hand paint silver so it off sets the engine a little. I also have to get another yoke for my drive shaft, get the seats in, etc.. Not a ton left. A couple days worth. I really likes the look of this intake. I hope it runs as well as it looks.
You should try and post some pictures of your set up. I would like to see it as I am sure many others would like.
Sinister is offline
post #613 of 694 (permalink) Old Feb 14th, 13, 11:34 PM Thread Starter
I finished re painting the letters on the intake and the BOV silver. Tomorrow I am going to try my hand and carbon wrapping the brace that holds the radiator to the support.
Here is an updated picture
Name:	Pro Flo 3.jpg
Sinister is offline
post #614 of 694 (permalink) Old Feb 15th, 13, 9:35 AM
Vinny Vince
So Del, what's the thinking behind using a glide? Was wondering if that would be an option for my Stang build, but it appears they are more costly.
*11 C6, 6.2, 6spd
69-CHVL is offline
post #615 of 694 (permalink) Old Feb 15th, 13, 9:20 PM Thread Starter
I'm glad you asked. Most people think my car is going to slow down but I don't. You know me, I love trying to do things against the grain.
Last year the only reason my car wouldn't launch for **** was because:
1. I was still learning how to tune and obviously couldn't get the launch part of it figured out.
2. I was never able to build boost due to a couple reasons.
a. I have the original back drum brakes and pads, so basically no back brakes. It seems as though to really build boost you need to be able to use the brakes to build it and get it going and then the transbrake once you get some boost already built.
b. I had tons of leaks on my hotside, none of my hotside was wrapped and sealed (which doesn't allow it to hold heat and build boost)
c. I had too steep of a gear so though I was getting a mechanical advantage and reducing the load on the engine, it is exactly that load that I need to help build boost. I now have 3.42 gears.
So my thinking is with the 3.42's, new rear disc's (going on next week) and my tuning has greatly improved (I hope) I think I can build 10-12lbs of boost which will get the car moving pretty good. I always felt as though first gear was such a waste anyways with my twins. When the thing finally took off it hit the rev limiter so fast that the gear seemed worthless.
Finally, some of the fastest turbo cars are using a glide. I would like to think that I will get my car consistently in the 5's this year.
Some other items that will help.
I pulled the amp and sub woofers out. I still have the stereo and all speakers but the amp and box was worth over 60lbs. I am personally 45lbs lighter this year due to training for an Ironman race in Texas. I also removed my inner fender wells. I could never get them to look good. I dented them so bad and cut them up. When I pulled them that was 38lbs off the front. I replaced my front seats that were heavy as hell with some Kirkey seats. **** that saved damn near a 100lbs. I always raced on a full tank. This year I will race on a half a tank. That is another 56lbs. So I did take off a couple hundred lbs from last year. I am hoping that will allow the glide to survive. I haven't weighed the car yet but hoping that it is under 3600lbs with me in it. Oh yeah, I also pulled the meth injection kit and sold it. It was 18lbs and my IAT's were plenty low in my opinion without the meth.
The track opens next week. I hope I can have her ready. Waiting on my drive shaft. I plan to run it at 10lbs and try to work on my launch primarily. Nothing else matters if I can't get it to launch.
Sinister is offline
This Thread is more than 917 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
