electrical problem - Chevelle Tech
post #1 of 1 (permalink) Old May 1st, 12, 7:56 AM Thread Starter
mark
electrical problem
I converted my alternator in my 70 chevelle to a 3 wire internal regulator. When you put the key in the on position the generator light does not go on. If I disconnect the radio lead ( the wire that allows the clock to run and presets to stay in) from the fusebox the generator light will work correctly. Any suggestions.
markw is offline
This Thread is more than 1854 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
