Does the ET match the MPH? - Chevelle Tech
 5Likes
post #1 of 27 (permalink) Old Jun 18th, 17, 1:51 PM Thread Starter
Ron
I was able to make a couple passes for the first time with new engine combo. I had some traction issues but was able to get one pass in the 12s. Based on the attached ET slip, is high 12s about all there is in this thing?
The car is a full dressed 66SS with a 461", 3:73 gears, 4 speed and 255/60 MT ET Streets. Not sure what it weighs but add my 240lbs to what it should weigh.
It seems my mph is high for the ET??
RLM66SS is offline
post #2 of 27 (permalink) Old Jun 18th, 17, 2:12 PM
Re: Does the ET match the MPH?
Your 60 foot is horrible. Your 60 foot should be about half a second quicker. That should translate to more than half a second improvement in ET. Provided you can bang gears real good.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Sea rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050" with .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger, Lemons 2" primary 4" collector, ATI 9" converter
Steve69SS396 is offline
post #3 of 27 (permalink) Old Jun 18th, 17, 2:13 PM
Vince
looks like your 60' was real poor
must have been spinning alittle
but with that mph and a good launch
i see low 12's or high 11's
by the math you should be able to go 11.60's with that mph and a good launch
VinceS427bb is offline
post #4 of 27 (permalink) Old Jun 18th, 17, 2:25 PM Thread Starter
Ron
Yeah I spun each time. Just the least amount on that pass. I had 18.5 lbs in the tires. A little to much RPMs I suppose. I admit to granny shifting the Muncie.. had to make it home.
RLM66SS is offline
post #5 of 27 (permalink) Old Jun 18th, 17, 3:10 PM
Dragway 42 lives!
I agree with the others, 60ft improvement will yield the most results. It's all about getting your launch technique down, no small task with a BB/4sp/255 tires. Do you have a close-ratio or wide-ratio 4sp?
114mph is pretty strong, though!
-Dave
'70 Chevelle ZZ383/700r4/3.55, 12.18@109 -- Megasquirt2-Extra, Holley Stealthram / Hotchkis A-arms / Hotchkis Springs / B-body 12" brakes / 1.25" F-body swaybar
ChevelleFan70 is offline
post #6 of 27 (permalink) Old Jun 18th, 17, 3:14 PM Thread Starter
Ron
Wide ratio. I put the M22 gear set from autogear in it. 2.56 first gear.
RLM66SS is offline
post #7 of 27 (permalink) Old Jun 18th, 17, 3:19 PM
Street cars usually don't ET as well as their their MPH would suggest, adding a manual transmission to the mix makes it even less likely.
There is a lot left in your car, there are probably many places to pick up ET. Like stated above most revolve around getting the car to work well in the 60ft.
Next time you go have someone video your runs starting with the burnout and staging.
Steve R
Steve R is online now
post #8 of 27 (permalink) Old Jun 18th, 17, 3:59 PM
Gary
Theoretical optimal ET is 1320 / mph. For 114 mph that would be an 11.57.
It's difficult to achieve even for some full drag cars. It's easier to make more HP to go faster than make a car hook harder.
My Nova has been a best of 11.64 @ 113.5 on slicks with a slipper clutch launching at 5K.
Gary
67AirRag is online now
post #9 of 27 (permalink) Old Jun 18th, 17, 4:26 PM Thread Starter
Ron
Well that is encouraging to hear. I know I will never truly optimize the power. The car is too nice and rare being a true 13817 to beat up. Shout out to Mr. Straub for the cam, AFRs, Morels and other goodies. I been waiting for 3 years to try this engine out.
RLM66SS is offline
post #10 of 27 (permalink) Old Jun 18th, 17, 4:56 PM
Eugene
Maybe you don't need to worry about it. Like you say the car is too nice and rare to beat up. If you get the car to start really hooking up you may start breaking things. The one thing you can take away from this is the car went 114 mph and that is pretty good.
mr 4 speed likes this.
Bonkerman is offline
post #11 of 27 (permalink) Old Jun 18th, 17, 6:05 PM Thread Starter
Ron
While agree 100% the only thing people care about is ET. Kinda like torque. No one ever asks "How much torque does that thing make" MPH isn't sexy... My coworker took his 2017 VW Golf R (2.0 liter turbo) down the track and went 12.54 at like 104 mph. Hard to swallow only running 12.90
RLM66SS is offline
post #12 of 27 (permalink) Old Jun 18th, 17, 7:35 PM
jeff
Yep broken record here. you need to get it to hook better.
255 tire. would be nice if you could stuff a 275 in there.
I ran my 78 nova for many years with different combos in it.
275-60-15 uniroyal tiger paw radials I could feather foot it to a 1.8 60 foot and 110 MPH best ET was 12.55 with those tires.
You mentioned spinning and air pressure.
I want to assume you did a burnout test on dry clean flat pavement to decide on best air pressure.
If not here it is.. every little bit will help.
Clean dry flat pavement do a launch and see what kind of tire marks you make.
Are the black marks light in the middle and really dark on the outside.. if yes you need more air pressure.
Is the mark dark in the middle only and very little on the outside.. if yes let some air out until the marks are evenly colored.
Your burnout technique may need work also.
Some tires will need more heat to get sticky.. during a burnout some tires will change pitch if you have a good ear.
I was running some dirt track tires at the drag race track and they would not hook.
I pulled the tires off my Ford van and stuck them onto my Nova and ran quicker they were 235-75-15 Goodyear wranglers.
Tall tires really work well to make things hook sometimes.
Nice to have many sets that will fit also.
I bet it was still fun for ya though.
jeff swisher is offline
post #13 of 27 (permalink) Old Jun 18th, 17, 8:09 PM Thread Starter
Ron
Ya know i did not test the contact patch. I just arbitrarily set the psi at 18.5. I did a minimal burnout as I was told the ETs just need to be rolled not smoked. The tires are almost done and I will go to the 275s next time. I did have fun but didn't realize it until after the 35 mile trip back home. Pretty stressful until then.
RLM66SS is offline
post #14 of 27 (permalink) Old Jun 18th, 17, 8:32 PM
Wow, that's the other end of the spectrum. That's a fantastic ET for the MPH. A little work on the launch, and you'll be there ET wise, but running away at +10 mph.
-Dave
post #15 of 27 (permalink) Old Jun 18th, 17, 8:40 PM Thread Starter
Ron
Yeah that little VW is all wheel drive with launch control. He has a tuner on it and actually has one more level of tune if he wants. It's only got 2900 miles on it. Pretty impressive
RLM66SS is offline
