Holley IFR relocation (jmarkaudio or gnicholson) - Chevelle Tech
 4Likes
post #1 of 23 (permalink) Old May 18th, 17, 12:02 PM Thread Starter
JIM
Jim/834
Mark or Gary,
Just be sure i have this right, I remove the brass restrictor from the upper outside holes that are drilled on an angle (circled in red) and tap the lower 2 straight holes circled in black for the new 6-32 x 1/8" set screws. Those 2 bottom holes are right next to another pair of holes that are drilled on an angle. I do not mess with the angled hole correct? Below is a picture of my metering block. Both of them are identical.
For the new set screws, I drill them to whatever diameter the upper ones are presently at?
My 70 Chevelle
The 454
Keisler/LGT SS700 5-speed
Best ET 11.37 @ 121 Mph
JIM is offline
post #2 of 23 (permalink) Old May 18th, 17, 1:14 PM
Mark Whitener
Re: Holley IFR relocation (jmarkaudio or gnicholson)
YEs, the bottom holes you can actually use either, I typically use the straight one going to the idle channel. If you have a bottoming tap start with 4 1/2 turns total, then test fit the set screw to make sure it threads in enough. If you don't have it more info at the links below.
racingfuelsystems.myfunforum.org - View topic - Relocating the Holley Idle Jet
Motorsports Village ? View topic - Two Circuit Holley Dominator Conversion
jmarkaudio is offline
post #3 of 23 (permalink) Old May 18th, 17, 3:10 PM Thread Starter
JIM
Jim/834
Thanks Mark,
Yes, I bought a 6-32 spiral cutting bottoming tap for the job. Also waiting for the #61-80 bit set to arrive that I ordered.
FYI,,, got a 50 set of 6-32 x 1/8 brass set screws from McMaster-Carr for under $5. Pretty good deal there.
My 70 Chevelle
The 454
JIM is offline
post #4 of 23 (permalink) Old May 18th, 17, 4:18 PM
Gary
looks like you have everything covered
gnicholson is offline
post #5 of 23 (permalink) Old May 18th, 17, 4:28 PM Thread Starter
JIM
Jim/834
Gary, yes, at least I hope so.
Just wanted to be sure before I start drilling and tapping stuff. Thanks for the phone support the other day as well. I appreciate your time given to me.
My 70 Chevelle
The 454
JIM is offline
post #6 of 23 (permalink) Old May 18th, 17, 5:30 PM Thread Starter
JIM
Jim/834
One last question... Pros/Cons to plugging the middle emulsion hole vs leaving it open in each metering block??
My 70 Chevelle
The 454
JIM is offline
post #7 of 23 (permalink) Old May 18th, 17, 7:26 PM
Gary
if thats a factory block im a fan of leaving the factory emulsion configuration alone unless you are willing and able to do a lot if testing. i would refer to mark on this
post #8 of 23 (permalink) Old May 18th, 17, 11:13 PM
#6? I thought it was #8?
post #9 of 23 (permalink) Old May 19th, 17, 4:52 AM
#6 if you're referring to the 6-32 thread, Tom.
Here's mine..
If you have a drill press (or a mill like I me) you can use an end-mill to spot-face for the IFR jet.
Be careful if using a drill press and use it's limiter so you can accurately control the depth of the spot-facing.
Post pictures.. -or it never happened!
BlackoutSteve is offline
post #10 of 23 (permalink) Old May 19th, 17, 5:35 PM
Mark Whitener
6-32 is typical, 8-32 can be used as well. And on a 3 emulsion block either plug the middle or close the bottom two to .020
post #11 of 23 (permalink) Old May 19th, 17, 6:48 PM
Vinny Vince
What effect does moving these have? If it's an improvement why wouldn't Holley do this from the factory?
*11 C6, 6.2, 6spd
69-CHVL is offline
post #12 of 23 (permalink) Old May 19th, 17, 9:44 PM Thread Starter
JIM
Jim/834
Vince,
See the 1st reply to this thread above by Mark. He posted 2 links. Look at the 2nd link (the motorsports village thread). Plenty of good reading/info there, but to answer your question, read page #6 of that thread and in particular the post by a guy with the username "shrinker". It explains the reason for the movement. Some of the Holley metering blocks already have the IFR's down there, some have them up high.
My 70 Chevelle
The 454
JIM is offline
post #13 of 23 (permalink) Old May 20th, 17, 12:01 AM
yes, #6 and #8 threads on the setscrews. not really going to mistake a #6 setscrew for a #6 hose?
post #14 of 23 (permalink) Old May 20th, 17, 10:35 AM Thread Starter
JIM
Jim/834
I modified the primary metering block.
Measured the existing upper IFR's to be .038". I removed them, drilled the set screws to .038" each and installed them in the lower holes.
Measured the e-holes to be .028" each so I took Mark's advice and plugged the center hole with lead shot.
If this all looks good, I will do the same to the secondary metering block. Let me know what you think.
My 70 Chevelle
The 454
JIM is offline
post #15 of 23 (permalink) Old May 20th, 17, 2:28 PM
Gary
from what i can see i would say you did a good job
